Looking for good stands for LSi7s
Mazeroth
Mazeroth Posts: 1,585
edited June 2004 in Speakers
Looking to find a nice CHEAP set of stands for some LSi7s. Anyone have any recommendations? Popular ones on Ebay or even Circuit City. I would like them to be adjustable height.
Thanks!
  • Mike682
    Mike682 Posts: 2,074
    edited June 2004
    I saw someone selling stands in this thread:
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=20048
    Hopefully these are what you are looking for.....I don't know if you can use these but it's worth a shot
    Mike
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • Early B.
    Early B. Posts: 7,900
    edited June 2004
    I would suggest finding the highest quality stands you can get, which may not meet your "CHEAP" criteria. The 7's are fairly heavy for their size. I initially had my 7's on a pair of $50 wood stands, and they weren't sturdy enough. If bumped slightly, they would have tipped over. Then I bought the partsexpress.com metal stands and these things are rock solid. They weigh 25 lbs. each and are sand fillable. Cost is about $94, but you can sometimes catch them on sale. A couple of weeks ago they were $69.
    "God grooves with tubes."
  • madmax
    madmax Posts: 12,434
    edited June 2004
    I plan on making a pair using 4" pvc tube as someone else posted here. I cannot recall who. You take 2 pieces of wood for the bottom and top, put two 4" diameter pvc tubes of whatever height in between, fill with pebbles, ball bearins, lead shot or sand and attach together with a threaded rod and some bolts. You can get off fairly cheap this way and end up with a better stand than you can buy. To make the 7's sound their best you need a very good stand.
    madmax
    Vinyl, the final frontier...
  • tryrrthg
    tryrrthg Posts: 1,896
    edited June 2004
    madmax
    That would be me! :D (I think)
    Pics
    The stands work great, they are SOLID! They won't tip over unless I use them for a tackling dummy.
  • madmax
    edited June 2004
    Those are great!!! I hope mine turn out that nice.
    This is actually the thread that got me thinking about it but I really like your diminsions and layout better for LSi7 sized speakers.
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=19539&highlight=diy+speaker
    madmax
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited June 2004
    My buddy from work does really great custom woodwork and he's planning on working with me to make some 32" stands that match the LSi styling almost exactly. I'll let you know how they turn out, should be very nice!
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • tryrrthg
    edited June 2004
    madmax
    Thanks! They were fun to build. I wish I had more patience when I was staining, I think I rushed it...
  • madmax
    edited June 2004
    Just wondering, what size is your bottom and top piece and how tall are the tubes? I'm just wondering because you got the relationship right which makes it look astheticly (sp) pleasing.
    madmax
