Replacement for RTi10 6.5inch midrange woofer
Need RD7217-1 replacement. Can't find anywhere. Wondering if the RD7218-1 from an RTi8 would work. Anyone have a suggestion for worthwhile non-Polk substitute?
  • agingboomer
    agingboomer Posts: 669
    <crickets>
  • Ryan_Polk
    Hey!
    You might find better luck with using the RTi A7 midrange driver part # RD6546-1. The cone color is darker and it will work just fine.
  • agingboomer
    Thanks @RyanC_Masimo , I was just coming here to post that very information. I emailed Polk Customer Service and they quickly responded with that substitution. Called and ordered one right away and it arrived this morning. Works like a charm.
