I have an old Polk Audio Surround Bar 360. I hooked the speaker to the receiver I use an optical cab
I have a polk audio surround bar 360. I hooked the soundbar to the receiver the sub out to the subwoofer. Nothing happens. I then hooked up an optical cable between the tv and the receiver. I get a picture but no sound thru the soundbar. Any ideas on how to connect this thing. I have a streaming service that plays fine, but no sound from the soundbar only sound comes from the tv speakers. Help!
Answers
    F1nut Posts: 52,277
    Go into the TV program menu, turn off the TV speakers, turn on external speakers or whatever it might be labeled.
  • dougehrhard
    Thank you for replying. I can do this through my tv menus, right. Also, do i have to connect the optical cable to the Polk receiver. Can I just hook the speaker to the tv and forget the using the receiver? Thank you,m
    F1nut Posts: 52,277
    Yes, the TV menu.
    I'm not overly familiar with that item, but I believe it came with its own amp/DVD player, which you would use to power the bar.
