SDA Questions
kingkip
kingkip Posts: 401
edited June 2004 in Speakers
Where can I get pictures of the SDA line, other than what polk has on their site. Also if you had to choose between 1c's and CRS's, which one and why. Thanks in advance.
There are two ways to argue with women. Both of them are wrong.
  • madmax
    madmax Posts: 12,434
    edited June 2004
    I have both and like both.
    I would get the CRS because it is so cool to hear that huge soundstage come from something so small. You have to have the stands too. Doesn't sound much different than the 1C's. They really freak people out because of their size.
    I would get the 1C's because they have sort of a clean non congested sound. There is sort of a silence you can hear between notes given a good setup and the right equipment. Less noise overall than all the other SDA's. They are a little more efficient, play louder and the bass is a little nicer (fuller) too.
    Either one is a great choice and the sound difference is small. With eyes closed you would be hard pressed to know which ones you were listening to unless you compared them directly.
    madmax
    Vinyl, the final frontier...
