Has anyone tried bridging the Momo C3002 into a 2 ohm load?
Systems
Systems Posts: 14,873
edited June 2004 in Car Audio & Electronics
Topic pretty much says it all. I want to try running a second Momo 10 (I have one) off this amp, but I wonder if it will even turn on with a 2 ohm load bridged? 1 sub per channel wouldn't have nearly enough power. So has anyone tried it?
Testing
Testing
Testing
  • [Deleted User]
    [Deleted User] Posts: 0
    edited June 2004
    NO! The 300.2 amp will only hold a 4 ohm mono load (2 ohm stereo).
  • MacLeod
    MacLeod Posts: 14,358
    edited June 2004
    Well if you were wanting a $400 paper weight you could try it.
    Or maybe if you needed something to tie to the end of your boats anchor chain you could try it!
    Fzzzt!
    Basically, dont try it. ;)
  • Systems
    edited June 2004
    Fzzzt!
    Yeah, I decided not to.. Even though it was only $200 for a paperweight, I can't get another one.
    Testing
    Testing
    Testing
