Marantz 2245 Won't Speak
SCompRacer
More tales from the bench. Very nice condition Marantz 2245 lights up but no output reported.
Check the OMRON relay first?Don't take experimental gene therapies from known eugenicists.
Check the tape monitor buttons. I've come across Marantz that had issues not getting contact & stuck not getting signal to switch over. Hope you find issue. Nice unitsRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
The relay does click and stay on. I checked the main caps first with a capacitor wizard, then powered it on. I'm getting 35v at the caps so good there.
I tried FM first and could hear a little static out of speakers. I cycled the antenna attenuator switch at rear from in to out and FM worked. That was the only switch that had not seen someone's application of Deoxit. After cleaning, FM plays with switch at in or out position.
I tried phono next and that worked. I had wondered about the tape monitor switch. The owner knows his way around a Marantz and did cycle the switch although it could have stuck internally. Maybe the 500-mile drive fixed it?
I'll test tape and aux input next. I'll also check power wires for poor solder joints. Unlike the Scott 340A and Scott 399 tube receivers I repaired, you can find lots of info on the 2245!
Thanks for the tips.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
edit -- oops.
