Will my oolk psw 250 power up my pair of t15s since the psw250 has a built in amp
Psw250 powering pair of t15s
Answers
    msg Posts: 10,650
    What's an oolk? I've never heard of that brand, but I'm intrigued.
    F1nut Posts: 52,406
    edited May 2024
    dabber wrote: »
    Ummm...NO!!!
  • boston1450
    boston1450 Posts: 7,759
    edited May 2024
    8k0836k3w3cl.png@dabber You will need a receiver/amplifier. You would use a single line (RCA cord) from Sub Out to Line In on back of PSW250.... The speaker hook ups on rear of PSW250 are used if a receiver/amplifier that have no Sub Out. So you could use it that away if needed. But more wires exposed... VVVV This is the back of a HT receiver. You can see Sub Out . Hope this helps 3l3juhn2y0b5.png
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    You will need to read/know settings on rec/amplifier to make sure it is sending signal Out to subwoofer. Also know settings on subwoofer to get the best out of it.. Use it easy & you may get years out of subwoofer. Use it hard pay the price :D good luck
    Randy-Maine
    by David WMG
