Tweeter Replacement In RT2000P
del44
del44 Posts: 686
edited June 2004 in Speakers
I've got a bad tweeter in one of my speakers. I even switched with other tweeter. Just incase it was a bad crossover. A small amount of sound comes out of it, but not near as much as the other tweeter. Has anyone put a replacement in? The metal dome stays on the bezel section when the tweeter is removed. Will I have to send the bezel section in with the tweeter when I get it replaced? Thanks.
    VR3 Posts: 29,756
    edited June 2004
    Nope - Step by step instructions here!
    To get a replacement, call Ken. Make sure u tell him you are a club polk member!
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=12227&highlight=tweeter
  • del44
    del44 Posts: 686
    edited June 2004
    Thanks for the help. My speakers should still be under warranty. Will go through some paperwork tonight to make sure. Man this sucks. Just brought home some new Rotel gear. (1068/1075)Wanted to listen to some music and watch movies. Now I may be without my main speakers for awhhile. Oh well!
    VR3 Posts: 29,756
    edited June 2004
    No problem dude -
    Polk ships out replacements parts free 2nd day air - plus u get a discount on the parts...
    Ken will hook ya up with a good price I am sure!
  • del44
    del44 Posts: 686
    edited June 2004
    ATCVenom, I would have sent you the 2000's a month ago. They were sounding just so-so. But now with the new Rotel gear powering them, hot damn they sound alot better than I could have imagined.. I sent the tweeter away today. I had to listen to music somehow, sooo. I removed the tweeter from the 400 center and installed it into the 2000. Oh yaa. just until my new tweeter gets here. I am using my old cs245 for the temporary center.:D FWIW The Polk rep that my wife talked to said Sony receivers cause alot of static and they can hurt the tweeters. He also said "tell your husband not to play his music so loud" oops!
    VR3 Posts: 29,756
    edited June 2004
    Sean - there are some on EBay for 450 + S/H
    Good luck!
