question about effeciency
jefft1314
jefft1314 Posts: 169
edited June 2004 in Speakers
i have a question for you all, I was checking out some car audio stuff, and before you tell me to post in the car audio section, i noticed a rockford sub with an efficiency rating of 85db and a maximum power rating of 1000 watts rms. This should theoretically achieve the same volume levels as a 91db sensitive subwoofer and a maximum power rating of 250 watts rms, right? If that's the case, then why is this subwoofer three times as expensive as the more efficient woofer, is this just exploitation of ignorance, or am I missing something here?
  • amulford
    amulford Posts: 5,020
    edited June 2004
    Sounds good though don't it?? 1000 watts power handling!!!!
    Dude, in a car It will literally deafen you in fifteen minutes.
