can anyone tell me what model these are?
Best Answer
What speakers do you have currently?
Answers
Appears to be Polk LS70 in high gloss rosewood.
thanks are these worth buying for 50 dollars?
Look pretty good. I'd say yes. Probably $200 in drivers if you parted them out (if they're working) -
You don’t get much in the way of speakers for $50 in working order (tweeters and drivers). That’s pretty much the price of an Alexa speaker or a Google Nest Mini. A pair of working LS70 would be far superior to those by many orders of magnitude.
I also recall owners of the LS70 describing them as very good, with more of a laid back sound profile. They may not be up to the Reserve or Legend lines of today, but you won’t be buying a pair of any of those for under $500, especially floor-standers.
Just check that none of the main drivers are frozen (from a displaced magnet) and that the tweeters are also working — use a tube from a kitchen roll to isolate the sound. It doesn’t matter if any of the brass connectors are missing between the rear binding posts. Those can be replaced with a short run of speaker wire. Tighten them up before doing any listening or testing.
That wood finish looks gorgeous! 🤩Alea jacta est!
