Carver AV-505 question?
MSkeezer
Hey guys, I"m wondering about something...On the back of the Carver, there are level controls for each channel, and the highest setting says "THX". Obviously this for THX certified speakers, but would it cause any damage to my LSi7's if I turn the controls all the way up? Thanks.
Thomas
Thomas
Post edited by MSkeezer on
If you don't have certified THX speakers then they will explode.:eek:
"THX Certification" is simply a 50 cent phrase to help folks choose equipment that don't want to do a bunch of research. Like marking software "Windows compatable." Your Lsi's will be more than adequate...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
