Trouble connecting with Banana plugs
bishopsnet
bishopsnet Posts: 18
edited June 2004 in Speakers
I'm trying to connect my CSi3 with banana plugs, but the connectors do not seat all the way. I had no problems connecting to my receiver. I bought the monster cable plugs. Does anyone know why this is happening? I tried to refer to the manual, and it doesn't have any info other than "take the cap of to insert banana plugs". I haven't tried my RTi's yet, but I'm assuming it will be the same situation.
  • ezc
    ezc Posts: 426
    edited June 2004
    How deep does the bananas go in. My bananas go in amolt all the way in but dosnt flush with the top of the binding post. If you unscrew the post nut & push in the banana you may find the banana is botteming out in the post. My Lsi do the same with bananas. It looks like it could go in more but it cant its bottemed out. If thats what yours are doing thats normal! Hope this helps.
  • bishopsnet
    edited June 2004
    My plugs go in just enough to barely cover the whole banana part of the plug.
  • ezc
    ezc Posts: 426
    edited June 2004
    unscrew the binding post all the way, you should have a hole in the post where the speaker wire is put through if using bare wire. Look in that hole to see if your banana is botteming out. It sounds like you may be bottemed out. Look through the hole in the post. If bottemed out your ok!
  • POLKOHOLIC
    POLKOHOLIC Posts: 407
    edited June 2004
    Push Harder...
    Hes trying but the hole isnt deep enough...:D
  • danger boy
    danger boy Posts: 15,722
    edited June 2004
    some guys just have longer bananas than others. waaaaaaaaaaaa! :p
    PolkFest 2012, who's going>?
  • bishopsnet
    edited June 2004
    Yeah, looks like I knocked the bottom out of it. My banana plug is large. I hope I didn't hurt the post to much.
  • POLKOHOLIC
    edited June 2004
    Is that right?
  • ezc
    ezc Posts: 426
    edited June 2004
    "Push Harder" I think thats exactly what my wife said last night! I know I wasnt bottemed out, but I had no more! Ok nuf of that. I have seen some bananas that was slightly large, try another banana, is it the same problem? Again look through the hole in the post is the banana at the bottem?
  • POLKOHOLIC
    edited June 2004
    ezc, its not that easy to try another banana....i mean..where is he gonna get another banana and how much is it gonna cost?
  • danger boy
    edited June 2004
    implants
    :rolleyes:
  • ezc
    ezc Posts: 426
    edited June 2004
    Try my banana? I may not bottem out either! Implants may be the way!
  • POLKOHOLIC
    edited June 2004
    bishop it will help if you measure the depth of the hole...that way we can all measure our banana's and see if which one will be a perfect fit.
  • bishopsnet
    edited June 2004
    I feel bad for people with small bananas. I did look through the hole, and my banana did bottom out. Crazy big banana, you might scare someone.
