Need guidance on my SDA SRS 1.2s
Tonofuns
Hello all,
I have been trolling this site for a long time and I'm ready to jump in. As a teenager I saw the SDA SRS 1.2 speakers in a mag and knew one day I would have to have them. Fast forward almost 40 years I have been sitting on a pair for the last 4 years. I thought I would have a new house built by now to enjoy them but it hasn't happend yet. I don't want to wait any longer and am using my sons old room for these speakers. Mind you I consider myself new to the adiophile world but I'm not a total noob....
I have read hours and hours of posts and have a great idea on what I need to do in order to mod/upgrade these speakers. I am afraid of electronics so I will have someone take care of the boards/wires but everthing else I can do including restoring the exterior wood finish. My main question for now is what am to use for power? I am still confused on this and I know there isn't one difinitive answer. I would like my best options on current linear amps/power amps along with vintage amps. I have a huge record collection that I would like to spend the rest of my life listening to. I'm willing to spend around 5k if need be but of course saving $ is always great. A local store recommended the luxman L-505uXII. My concern is does this have enough power and is it common ground? Almost all of the posts say to get at least 200 watts per channel but I also understand more power doesn't always mean better. Any advice will be greatly appreciated and I have more questions but one at a time seems fair.
Answers
They do? Other than the mantra of one that's news to me.Almost all of the posts say to get at least 200 watts per channel
That Luxman is a fine piece of kit, but I'm going to suggest looking at the integrated amps from Musical Fidelity. -
F1nut I appreciate your candor and expertise and always read your posts and appreciate your knowledge.
I should have worded my sentence differently. Many of the posts that I have read on the subject of powering the SDA SRS speakers seem to me to make sure to have more power than not enough. They seem to require quite a bit of power and I'm just seeking for advice on how much is required and how much would be ideal.
I know this can be very subjective but any advice is better than none. I see many amps ranging from 100-500 watts per channel at 8 ohms but I also understand that not all of these are created equally. A top end 100 watt amp might be much more powerfull than a poorly built 400 watt amp. As for finding a common ground amp I guess I will have to ask the dealer or manufacturer because I can't seem to find that listed on the spec pages. I was hoping to hear back from fellow SDA SRS owners on what they are using and I then can educate myself on their setup. I do appreciate your suggestion on Musical Fidelity and they seem to be solid.
I wouldn't focus solely on the watts, these SDA's enjoy amps, as in current (amperes).
With your budget, there should be no problem reaching a quite happy listening experience. The MF gear is good stuff, and I'm sure others will chime in on other ideas.
Good luck with your journey.
