Rear speakers need em or ditch em?
denis87
I dont know if i should upgrade the rear speakers in my 04 civic since they are a **** to replace. you have to remove the whole rear deck which means removing the rear seats. What do you guys think is it worth the time and $$?
www.dmbvideo.com www.oilfans.com
Post edited by denis87 on
From a strict SQ perspective, you dont need rear speakers at all. They pull your soundstage to the rear and with the same frequencies coming at you from 4 different distances, it can smear the detail slightly. Now your SQ wont suck with rear speakers but using front only will always be better.polkaudio sound quality competitor since 2005
Originally posted by MacLeod
From a strict SQ perspective, you dont need rear speakers at all. They pull your soundstage to the rear and with the same frequencies coming at you from 4 different distances, it can smear the detail slightly. Now your SQ wont suck with rear speakers but using front only will always be better.Music is like candy, you have to get rid of the rappers to enjoy it -
yeah in my other thread about an amp for the mm6's i wasn't sure if i wanted a 2ch or a 4ch. it all depended if i need power for the rears. so now i might swap my kicker 4 ch for a new 2ch with more juice and have the stock rears running off deck power only to be used when i got passengers in the rear at odd occasions. yeah you guys are also right about the sq. especially in my civic it sounds really sh*tty with rears on. thanks for the help.www.dmbvideo.com www.oilfans.com
whats the rms rating of the 4 channel you already have?
oo ok...if it was more in the 75x4 power range youd still be able to use it
go with a new 2 channel that does like 125-150 watts rms:D
what about for my subs? they're two jl 12w0's and i got an rf 200 mono running them. you think i should upgrade that too?www.dmbvideo.com www.oilfans.com
what is the impedance and rms power handling of the w0s?
and whats the model number of the amp?
-Cody
http://www.jlaudio.com/subwoofers/12w0.html
rockford fosgate 200Mwww.dmbvideo.com www.oilfans.com -
assuming your subs are the 4 ohm version...that amp probably puts out the rated RMS of those subs...id keep it
yeah they are 4 ohm. I've heard they are underrated in power but i think they sound great for my everyday use. although who wouldn't want better gear. if it snowed money i'd buy a new system every year. actually since i have two subs then for optimal performance i should have 300w pushing them right?www.dmbvideo.com www.oilfans.com
JL subs are known to be a little underrated, you probably could throw 150 each at em and theyll take it fine
Originally posted by denis87
40wx4 rms @ 4ohmhttp://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
Alpine 9815
Ascendant Audio Atlas 12
2 Gallons SecondSkin Spectrum V.2 -
Yeah but my manual for the amp doesn't say anything about hooking it up like that. Wouldn't it sound like crap since the signal is now mono?www.dmbvideo.com www.oilfans.com
Im not a big fan of bridging 4 channel amps for mids/highs. It kicks up the THD quite a bit and makes the amp work at full power all the time. Im not saying its wrong to do so, I just dont prefer it.
And those JL's are way underrated. If you go to the spec page and download the 12W0's data sheet it shows you these things can take over 200 rms.polkaudio sound quality competitor since 2005
right now i'm running the gain on the amp higher than i should so they'll be at a volume i like. not nearly as high as in the older car i had since it was a much bigger car.www.dmbvideo.com www.oilfans.com
Be careful in doing that. Punching the gain up too high could very well result in clipping and burn those JLs. Not to mention a lot more distoriton and the bass generally sounding like crap!polkaudio sound quality competitor since 2005
hmm it's been like that for 2 years now maybe i should do some readjusting. good thing i don't crank up the volume to loud.www.dmbvideo.com www.oilfans.com
