Polk Audio port technology questions.
ChrisD06
Short and sweet.
I'm working on a little project. I'm curious if anyone knows how one could design their own ARC (Acoustic Resonance Control) port and tune it to a cabinet, and also how I could design my own Power Port to tune to a cabinet.
Looking at making some RTxxxp matching surround speakers...
My gear:
- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
The arc port was tuned to the resonance of the cabinet. I honestly wouldn't bother trying to replicate this... Polk ultimately has dropped the tech on the newer stuff- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The math for Helmholtz resonators is well established. Nothing magical about ports. It is classical (i.e., non-quantum) physics.
The shape makes the arithmetic a little more complicated (and, at least in theory, minimizes port noise), but... calculators, computers, and the good ol' spreadsheet take most of the tedium out of doin' the arithmetic.
From what I've found, Polk's PowerPorts are relatively the same port volume as a standard tube/port, but with that volume residing outside the cabinet within the platform area itself and a very short tube inserted to enclosure.
There was an excel spreadsheet on the net with the PPort calculations also requiring known driver TS parameters etc. I posted the basic platform/port dimensions ratio diagram here somewhere....
Edit....
Don't take experimental gene therapies from known eugenicists. -
The arc, acoustic resonance control port is not the power port- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Thanks, Trey. I will probably end up not replicating it, but I have always been curious how it worked and what it was even supposed to do.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
Edit....
Oh shoot! If you happen to run across that spreadsheet please send it my way. Otherwise I'll have to do some trial and error using the diagram.My gear:- TCL 75QM7K TV
- RT3000p Fronts
- CS1000p Center
