Polk Audio Subwoofer PSW111 feet
Hi All,
I bought some SVS soundpath isolation feet to replace the stock feet in my Polk Audio PSW111. However, realized that it is not compatible as the thread size is too small. Is that truly the case or am I missing something?
Thanks.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,397
    Hello,
    The feet are held onto the cabinet with screws:
    For using a threaded type foot the holes would need to be enlarged and "tee" nuts installed.
