Feedback
My sub has some feedback in it. I can't seem to figure it out. Help?
Answers
    treitz3 Posts: 20,239
    Do you have a grounding cheater plug? Also, could you describe the best you can, the exact sound you are talking about?
    You might also try moving the power cords in your system away from your low level interconnects, or cross them at 90 degrees (not in parallel).
    One more question, do you have any florescent lights or dimmers on the same circuit?
    msg Posts: 10,593
    <<<\\\ A+++!!! Arrived just as described!!! Would shop with again!!! ///>>>
