Acquired a pair of SDA2s
Hi all,
I acquired these SDA2s about 3 years ago. They came out of a shed that a gentleman was cleaning out I paid 50 bucks for them. I figured i couldn't go wrong since they had a good name brand name attached to them.
I used an old Sony receiver from the 90's to power them and test them out they sounded amazing. I really haven't used them since.
I am just now getting around to seeting up a system in my bedroom and want to use these speakers. Once I looked up the model number I discovered this site and the nuisances surrounding these speakers with terms like common ground amps, interconnect cable pin/blade and blade/blade.
My question is what do I have here and how do I move forward on acquiring the correct components to properly power my setup.
    pitdogg2 Posts: 27,552
    They appear to be SDA2b
    Clipdat Posts: 13,100
    Did he include the green oxidized speaker wire too?
    audioluvr Posts: 6,010
    edited February 2024
    Nice score! They will need to be updated. The surrounds on the tweeters have separated which could be repaired but would be best to replace them with the RD0-194's or the RD0-198's if you choose to "TL" them. Get your read on and welcome to Club Polk.
    F1nut Posts: 52,149
    RD0194-1 or RD0198-1
    xschop Posts: 5,658
    Get a can of Polk-Black spray paint for those chipped tops.
  • Clipdat wrote: »
    Yes, he did lol. Green is the new gold!
    Audioluvr, thanks for the reply. Looking into the RDO-194s and 6s so much info here to go through. I tried to keep this rabbit hole at bay, but I keep inching further and further.
    Toolfan66 Posts: 18,287
    Just at glance, if you plan on keeping them, by the looks of the tweeters I would open up the cabinets and inspect everything, backs of the drivers, crossovers, etc. Especially since you said they were in a shed..
    I would then order the RD-0194 tweeters, I am assuming these have the two piece crossover boards. If by chance they are the one piece, get the RD-0198’s and upgrade the crossovers to accommodate them..
    There is more but it’s a good start.
  • joebass3
    joebass3 Posts: 311
    My SDA-2b studio (black cabinet) version had the blade/blade interconnect socket like yours. Luckily they had the single board crossovers and I was able to do the "TL" mod. Definitely take a look inside and see what you are working with.
    F1nut Posts: 52,149
    Leanback wrote: »
    Clipdat wrote: »
    RD(zero)194-1 or RD(zero)198-1.
  • Ok, I went ahead and opened up and inspected everything. I believe everything looks good no corrosion on the boards or speaker connections. But I'll let you guys be the judge of that. Also I didn't pull out the stuffing to see if there was anything else in there let me know if I missed something.
  • F1nut wrote: »
    Leanback wrote: »
    Clipdat wrote: »
    Thank you for the clarification F1nut
    Can you tell us what the serial numbers are? you definitely have the single boards (that is a good thing) ..
    Left Channel 14115 or greater.
    Right Channel 14124 or greater.
    Your right channel hits the mark, at 14831, I would assume the left will as well.
    You will be able to upgrade these to 2BTL's and use the RD-0198-1's and you can also use an AI-1/Dreadnought SDA Cable if your heart desired..
  • Toolfan66,
    Left channel serial # 14608
    Right channel serial # 14831
    Looks like the both hit the mark, thanks for that info.
    Is there a amp/receiver compatibility list for these speakers put out by Polk? I keep seeing this common ground issue while using the interconnect cable.
    Leanback wrote: »
    Toolfan66,
    If you can find a AI-1 cable or Build a Dreadnought the world is your oyster for powering these, even mono amps..
    You shouldn't have an issue with most receivers, plenty of guys around here that can chime in on them.
    xschop Posts: 5,658
    Toolfan66 wrote: »
    Leanback wrote: »
    Toolfan66,
    Even Class D
    Your left side drivers look like the magnets are shifting. Gently push in on them to listen/feel for scratchiness. They may need to be recentered before you secure the magnets.
  • audioluvr wrote: »
    Yep, I see that in the picture now that you mention. Thanks for looking out.
