All Tapped Out???
I am sitting here listening to my wonderful L800's, being fed by my tube amps, Arcam AVR20, and Simaudio 680D DAC... it sounds fantastic, but out of curiosity and a desire to get even more out of the Legends, I picked up a Pass Audio XP20 a couple weeks ago. I have been using it for the past week or so and I'll be damned if I can hear any improvement over the Arcam.
They sound virtually identical, and before we assume something must be amiss with the Pass, before I set it up, it went to Pass Labs for refurbishment and was found to be in flawless condition. I let it settle in for 48 hours before doing any serious listening. This leads me to the realization that perhaps the Polk Legends may be performing at the peak of their ability and there is nothing left to squeeze out of them. This thought flies in the face of everything I have come to expect, so I thought I would post this and get some input.
Might it be time to move on from Polk?
    VR3 Posts: 29,624
    May just be time to move on from pass labs. Don't get to hunt up on brands, I've tried maybe 20 amps on my speakers before landing where I'm at. Constantly making decisions based on brands you've always used may deliver no results
    Clipdat Posts: 13,100
    You've got a bottleneck/weak link somewhere in your system and it isn't the L800 imo.
    treitz3 Posts: 20,203
    Honestly, that was the first thing that came to mind, Drew. Whether it be a cable or something else holding the system back....
  • Emlyn
    Emlyn Posts: 4,864
    Could also be the tube amps have a strong enough character of their own to mask major differences in that system the way it is configured now between the very competent Arcam and Pass Labs preamp sections. I wouldn't call that a bottleneck if that is what it is. Could just be that both preamp sections have the same type of synergy as each other in that system. If the Arcam is performing as well as the XP20 that's a very good thing!
    I'd try an AVR or cheaper preamp in the system that I knew to sound worse than those two to see how the system sounds with everything else the same. I suspect it'll sound quite a bit worse, tinny, with a crushed soundstage. Then it would just be a case of the Arcam and Pass Labs just being very good and performing similarly in that system.
    billbillw Posts: 7,952
    I'm sure you have heard of the law of diminishing returns. It has never been more evident than in the audiophile gear world.
  • Emlyn
    Emlyn Posts: 4,864
    In the systems I have L800s in I find them to be the most neutral and open sounding speakers I've had. Not overly revealing bright/detailed sounding and not syrupy warm. The speakers sound as good with a Marantz 8805a AV preamp as they do with a Parasound JC2 preamp. I tried using a JC2 in home theater bypass mode together with the 8805a and didn't hear enough of a difference to keep it in place.
    Sources were another story. Considerable audible differences there.
    VR3 Posts: 29,624
    the source is everything!
    But.....I would make the friendly argument that everything affects everything. The source is a very important part of the equation but then again? All it takes is the weakest link to restrict the point of diminishing returns.
    Lose that weak link and your returns can offer you so much more.
    nooshinjohn Posts: 26,058
    treitz3 wrote: »
    Cables are all mid-level AQ or better, so I don't think it would be those...
    Emlyn wrote: »
    That is interesting… Doug has a similar Marantz, maybe even the same one. He also has a Pass X1. In his system, there was a huge difference in sound, with the Pass Labs sounding better than the Marantz by a considerable margin. I had hopes that my experience would be similar. I think I am going to move on from the XP20 and hold my ground for a while. Moving on from my amps is a non-starter for me and any other move will need a lottery win to accomplish.
  • jbreezy5
    jbreezy5 Posts: 1,141
    edited January 2024
    Emlyn wrote: »
    I think Emlyn has a good idea with swapping out other preamps (regardless of price) with which you are familiar with their sound characteristics, to find out if you can pick up on those differences.
    If not, that would beg the question “Why?”. Then go from there.
    I speculatively wonder if the mid/tweet configuration of the L800s might cause frequency response cancellations affecting soundstaging/imaging cues, and whether that might somehow render equipment changes less noticeable.
    Good luck with your experiments.
  • dpowell
    dpowell Posts: 3,081
    Emlyn wrote: »
    In my system the Marantz 7704 does not come anywhere close to the Pass Labs as a 2 channel pre. When John brought down the Moon 380D a few weeks back, it only took listening to 1 song on the Marantz to tell me that either the DAC wasnt the right fit or the Marantz was completely lacking as a pre. Putting the Pass X1 back in the mix was night and day difference. ICs used are WireWorld silver eclipse. Never heard the 1.2TLs sound this good! I may be in the same place as John now; a place where i can be satisfied for years to come.....as long as John doesnt make me listen to another new piece of gear.🤣
  • jbreezy5
    Found the following quote from an Audioholics review:
    “SDA is a kind of analog acoustic crosstalk cancellation. It uses speaker drivers placed precisely the distance between the average human ears on each cabinet to achieve crosstalk cancellation. The outer midrange driver and tweeter of each L800 speaker produces an inverted signal of the opposite speaker. This is an attempt to cancel out the sound of one of the speakers from reaching the opposite side ear. The cancellation method is similar to how active noise cancelling headphones work; generating a sound of the same amplitude but opposite phase negates the original sound. Polk’s new “Pro SDA” updates the original SDA by incorporating improvements including headshadow response, which allows the SDA cross-talk cancellation to be expanded into the treble region without serious interference problems. The Pro improvement adds a 15-degree baffle angle which helps narrow the speaker overall while also building in the toe angle needed for best sound. The new technology does a better job matching the true interaural crosstalk distortion created with most speakers and thus more completely cancels it.”
    He spent a lot more words describing the technology and design goals Polk Audio had on the L800s. Maybe that could give further insight as you experiment. Full review in below link:
    https://www.audioholics.com/tower-speaker-reviews/polk-legend-l800
