Dont want to spend $1,000 on Amps, Which system is better?
AintJoM0mma
I want a good system. But for now I want to spend the least money possible driving it. Which of the 4 systems listed below would be easiest to drive and provide the best sound?
System A:
-2 LSi9's and a Sub
then later
-2 LSiFX's
-1 LSiC
System B:
-2 RTi150's
then later
-2 FXi5's
-1 CSi5
-Maybe a sub
System C:
Same as System A but with LSi7's
System
Same as System B but with RTi12's (Will probably sound the same)
Thanks:D
System A:
-2 LSi9's and a Sub
then later
-2 LSiFX's
-1 LSiC
System B:
-2 RTi150's
then later
-2 FXi5's
-1 CSi5
-Maybe a sub
System C:
System
Thanks:D
I = NOOOOOOoooooo000b
AJM I can tell you from personal experience that either the 150s or 12 will require seperate power amps just as much if not more so than the LSIs will if they are set to "large"or full range (as they should be). However, a receiver will have a much better chance at powering a whole ensemble of RTis than 4 ohm LSis
What will you be using them for? If mostly movies and/or rock/pop music, then I vote for the RTis. If mostly for classical music, jazz, opera, etc., then I vote LSi.
I know it's cliche, but you have to listen to them both and decide for yourself though -
if you dont have bread for amplification, smaller RTi's and a sub might be a better bet
maybe RTi6 and a sub or the RTi8 and a sub or the older equivelents like the RT70 floorstanderLiving Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Do they sound as good?
If I had to buy a receiver and an amp could you guys recommend the cheapest possible solution that would still sound good?I = NOOOOOOoooooo000b -
audiogon and ebay used might be your best option. definitly the best bang for the buck. much of my theater and 2 channel rig were bought used with great results for relativly little $Living Room 2 Channel -
I know the sites but what model # of receiver and amp would be te best combo (price/performace wise) for RTi150's or RTi12's?I = NOOOOOOoooooo000b
do you do more home theater?, or music listening.
how much of each?Living Room 2 Channel -
