Musical Fidelity KW Hybrid Preamp
nooshinjohn
Just wondering if anyone has experience with the Musical Fidelity KW Hybrid Preamp. I am looking at one that looks to be very clean and I am looking to see what you guys think of that model, or would I be better off looking at one of their newer models instead.
Has zero sonic signature. Adds nothing, takes away nothing.
Very well built but it is MASSIVE- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks… is it worth 1300 bucks?Has zero sonic signature. Adds nothing, takes away nothing.
Very good deal, imo- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Over a Pass Labs XP20?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I'm not a pass labs fan so I'm biased, pass labs has a sound signature that will alter everything after it so as long as you like that you should be fine- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Musical fidelity has always been solidMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
