RT2000i amp replacement
MAZ
MAZ Posts: 29
Looks like running passive requires more effort than i have time for.
So i see ebay has amps. Is there an upgrade amp available now or am i stuck putting in another SA100 in it ?
  • MAZ
    MAZ Posts: 29
    Just looked. $175 is a bit much for a replacement amp thats already what i consider a ****.
    I have a nice set of xovers from a pair of B&W speakers i need to look at. I can work around the stock amp issue even if not optimum. These are just experimental speakers i got for $150.
    I have all i need already just about.
    Worse that could happen is blow up a driver or xover i guess.
  • SeleniumFalcon
    You might want to consider having a local electronics repair shop look at the defective amp. Usually there's not a lot that fails in these designs, power supply filter capacitors, sometimes a voltage regulator. Nothing a repair shop hasn't seen before. If I remember correctly there was an eBay person who was repairing plate amps mentioned in the past.
  • ChrisD06
    ChrisD06 Posts: 929
    What's the problem with them? Most of the time the filter caps go bad, sometimes the voltage regulators do.
    You can always replace these yourself, or find a tech to do it for pretty cheap. Use Cornell-Dublier Electronics 105°C rated caps and you're off to the races.
    Running them passive is an option but the amps in these speakers are pretty darn reliable once you repair them. I recall that the capacitors in them were made during the capacitor plague but I'm not sure how it affected Polk's amps.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
  • MAZ
    MAZ Posts: 29
    I just got them last night. For all i know it could be a fuse.
    Im thinking the options. From what ive seen there isnt a lot to it so it could be fixed.
    I need to bust open the non working and see whats up.
  • ChrisD06
    ChrisD06 Posts: 929
    MAZ wrote: »
    Have you even tested them to find out they don't work? If it's humming, it's probably just the filter caps. If there's no light, my guess is fuse.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • MAZ
    MAZ Posts: 29
    ChrisD06 wrote: »
    MAZ wrote: »
    When i picked them up 1 was working 1 was not. I knew that when i went to get them. By that i mean the sub amps playing sound. I didnt examine anything
    Brought them home and put them in my office. I will check it tonight.
