SDA 2b with blade interconnect cable
jbail2011
Hi all! You folks helped me restore a sweet pair of SDA 2b’s. I got these from my father in law 20 years ago. Well it turns out he had another set and he just gave them to my daughter! So here we go again! Except this time, her pair has the blade interconnect and mine didn’t.
Why is the blade interconnect important? I recall during my restoration people eagerly asked me if mine were bladed… followed by disappointment when I said they weren’t.
Thank you in advance for your responses.
Jeff
Jeff
Polk Audio SDA SRS 2.3 TL
Polk Audio SDA 2B TL mod
Carver M 1.0 MK2 Opt 2 x2
Carver CT Seven Preamp
Bluesound Node 2i
Bluesound Node 2i
Early SDA2b did have a blade/blade socket that was wired like the pin/blade socket. FIRST are you sure they are not SDA2a ?
Are they a single board crossover or dual board??
I’m not sure. I will check! Thank you
Bluesound Node 2i -
You can either pull a driver and check numbers or pull the passive and look at the XO. 1 board will be 2b, two boards will be 2a. SDA2a has both drivers as MW6510 -
That makes little sense.Why is the blade interconnect important? I recall during my restoration people eagerly asked me if mine were bladed… followed by disappointment when I said they weren’t.
They either have a pin/blade cable or a blade/blade cable, so both have a blade. The pin/blade version is more desirable due to the ability to use the AI-1 or Dreadnought isolation transformer, which allows one to use non-common ground amplification.Political Correctness'.........defined
President of Club Polk -
Thank you! That’s the answer I was looking for! These are blade blade.
Bluesound Node 2i -
I haven’t been able to get into them yet but I am assuming they are 2b because my left channel serial number is 16035 while hers is 16292.
Bluesound Node 2i -
There are a few Blade/Blade 2B’s that were produced and one can still use the AI-1 or Dreadnought isolation transformer, which allows one to use non-common ground amplification.
This is why I asked if they are a single or double crossover board, the serial numbers can help as well, but opening them up will be the tell all. -
I’ll have my hands on the soon and let you know. Thank you!Polk Audio SDA SRS 2.3 TL
Bluesound Node 2i
