Herron VTPH-2A Phonostage
After waiting patiently for a long time, and missing a few chances, I was finally able to buy one of these units. It's not hard to find praises on the internet for Herron VTPH phonostages, but since Keith Herron has stopped producing new units, it is becoming harder to find 'legacy' products for sale. Besides phonostages, he also made line-stage preamps...and a few other products. Sadly, his entire herronaudio.com website is now gone, so there's no 'official' reference source for his products.
Undeterred, I purchased a VTPH-2A off the used market. These are tube-based phonostages, with 5 tubes in the circuit. One factory configuration incorporates (2) 12AX7, and (3) 12AT7; the other configuration has (4) 12AX7, and (1) 12AT7. The difference in configuration results in different levels of gain. My unit has the (2) 12AX7 and (3) 12AT7 configuration, so a lower level in overall gain.
The rear panel of the unit shows that there are separate inputs for MM and MC cartridges, with a toggle switch to basically adjust for the gain level between MM and MC. Alongside the MC inputs are a pair of RCA inputs for cartridge loading purposes.
The loading 'plugs' are basically RCA plugs with resistors soldered in-situ for the desired load. The owner's manual suggests trying MC carts first with NO load (due to special circuitry), and I can't disagree with that. I listened (first) with no load (no plug) on an MC cart, and then again with appropriate loading plugs in place, and I think it comes down to personal preference. If someone has come this far in their vinyl playback journey, it is worth experimenting with loading options in order to determine the best result in their particular setup.
Okay, this concludes the background information on Herron VTPH phonostages. Listening impressions are forthcoming.
  • jbreezy5
    jbreezy5 Posts: 1,141
    Great phono pre! Congrats!
  • tratliff
    tratliff Posts: 1,865
    Very nice. Would love to be able to give it a listen
  • newbie308
    I will be looking forward to your review after spending some time with it. I have been eyeballing the VTPH-1. I'm curious about the noise floor when using the MC input.
  • jdjohn
    jdjohn Posts: 3,429
    Belated thanks, guys :) I've been doing comparisons between these three:
    The one on top is the Herron VTPH-2A, middle is a Bigbottle Audio 3 (BB3) (originally mentioned here:
    https://forum.polkaudio.com/discussion/196639/big-bottle-audio-bb3-tube-phonostage/p1 ), and on bottom is a Musical Fidelity Nu-Vista Vinyl. These are all tube-based phonostages, and not a bad one in the bunch, so tedious testing involved.
    pitdogg2 Posts: 27,713
    What a tough job😉. Good luck Jody.
  • jdjohn
    jdjohn Posts: 3,429
    Ivan, the struggle is real! Tough, and demanding crowd here...well, except for Trey. He has zero interest in analog.
