DIY Lazy Susan Turntable
SCompRacer
Not for records, but for giving gear a spin on the bench. Borrowed this idea from Xraytonyb on you tube. It’s a pain moving a heavy receiver around on the bench while inspecting, ohm/cap testing or replacing capacitors to get a better angle.
Lazy Susan’s come in various sizes and weight ratings like 4”, 6” , 500 pounds, etc. I chose a 12” one so if the gear is slightly off center it won’t tip allowing the platform to rub the bench. (It’s rated at 1000 pounds…LOL). Cost me $15 at Lowes. I didn’t have any decent plywood laying around so got a 2’ x 2’ piece of 3/4" for $11. I cut it down to 21” square.
I drilled a hole in platform to allow access and attach it to the bench or attaching a wood base in the future. I rounded the corners and used a router to radius the top and bottom edges. Followed up with a sander. Should have made this when doing the Scott 340.
Cool Rich. Where did you get the round base? Saw this one at Amazon but doesn't match your $15 cost
EDIT: Duh.....nevermind...
https://amazon.com/Woodpeckers-Lzy-12-1-Capacity-Hardware-Turntable/dp/B071ZD31Z5/ref=sxin_16_pa_sp_search_thematic_sspa?content-id=amzn1.sym.44176409-a507-4684-9fe6-68e5d09ea23a%3Aamzn1.sym.44176409-a507-4684-9fe6-68e5d09ea23a&crid=1CI830BDUXNS8&cv_ct_cx=lazy+susan+hardware&keywords=lazy+susan+hardware&pd_rd_i=B071ZD31Z5&pd_rd_r=c93e6a0e-0723-4c3b-a63d-d78f4eea7a07&pd_rd_w=SnoUT&pd_rd_wg=ajMNq&pf_rd_p=44176409-a507-4684-9fe6-68e5d09ea23a&pf_rd_r=ATRK3E74YJ8BD2CGVCYB&qid=1698369783&sbo=RZvfv%2F%2FHxDF%2BO5021pAnSA%3D%3D&sprefix=lazy%2Caps%2C246&sr=1-1-2c727eeb-987f-452f-86bd-c2978cc9d8b9-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9zZWFyY2hfdGhlbWF0aWM&psc=1_________________________________________________
Yup. Slow today._________________________________________________
The Amazon one looks identical to the one I got. The Richelieu one I got costs even more at Amazon....$26.91.
https://www.amazon.com/Richelieu-Hardware-UC548812-Swivel-Plate/dp/B071166LTQ?th=1Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
