Parasound HCA-1000 vs. HCA-100A
  • skrol
    skrol Posts: 3,472
    I can't fully compare the upgraded caps to the originals since the originals were bulging when I got the amp. However, I certainly do feel it is worth the upgrade even to get a little more voltage margin. The originals were 60V which is right at the rail voltage. The originals were chosen because they were the highest capacitance that would physically fit the dimensions. Mr. Curl indicated that this was a shortcoming of the amp. As advances were made, higher capacitance and higher voltage spec caps became available in that same physical size.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • gp4jesus
    gp4jesus Posts: 2,019
    12Kuf/63V or 80V?
    15Kuf/63V or 80V?
    Make & model?
    on eBay.
    Nichicon 12Kuf/71V - 2/$18 shipped.
    Elnas 10Kuf/63V - 2/$10.14
    *all connected w/Premiere ICs
  • skrol
    skrol Posts: 3,472
    I used Nippon Chemi-Con for the power supply caps. They have a good reputation and met the physical constraints.
    Stan
    Main 2ch:
    HT:
    Other stuff:
