Help Identifying
Sorry for the less than great pic, but it was the best I could do in the moment. A Google image search revealed 7As 7Bs and the like, but none of them seem to be a perfect match. The most glaring difference is the size of the midrange dust cap. I suppose it's possible these were repaired or modded at some point, but just curious if anyone could identify an exact match. TIAnpz57xi5cjdv.jpg
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
    F1nut Posts: 52,165
    The mid-driver has been replaced with who knows what.
    xschop Posts: 5,665
    Looks like a Dayton DC-160.
  • Gardenstater
    Gardenstater Posts: 4,858
    That could be what is in there. 35mm aluminum voice coil. Would have to have a larger dust cap. 86.1dB SPL at 2.83V/1m is possibly lower output than a MW6500 though. Fs of 35.7Hz.
    https://www.daytonaudio.com/images/resources/295-305-dayton-audio-dc160-8-specifications-46146.pdf
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    mhardy6647 Posts: 35,394
    Just to clarify the above posts. It use to be a Monitor 7. It isn't any more.
  • Gardenstater
    You got short changed. I thought for sure you'd get at least 6 Agrees.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,665
    Rebuild the crossover, butyl mat outside and foam the inner basket frame, place a dowel front-to-back in between the MW and PR, then have a listen.
