breaking in db6500s
rodney
i just installed a set of the db 6.5 components, and was wondering how long i should break them in. also, the tweets sound like they are playing louder than the woofers, is this just cause they arent broken in yet?
alpine cda-9857
polk db6500
polk ex369
polk/momo mm104
profile ap1040
kenwood kac-7251
polk db6500
polk ex369
polk/momo mm104
profile ap1040
kenwood kac-7251
Post edited by rodney on
Where are the tweets located? If they're a lot closer to you than the woofers, well then... they'll be louder. Also, what are the settings on your CD player?Brian Knauss
ex-Electrical Engineer for Polk -
the tweets are in the a-pillar, and the mids are down in the door panel. which settings do you mean? i turned the treble down some if thats what you mean. it helped some.alpine cda-9857
polk db6500
polk ex369
polk/momo mm104
profile ap1040
kenwood kac-7251 -
I didn't break mine in, I just started playing them. They sound better and better over time but they were great to begin with.
My tweeters are on the door pillar.
How do I attach a photo that is on my HDD to this thread?Polk db6500 [front]
Polk db650 [rear]
Polk MOMO MM12 [2]
PolkAudio RT600i [front]
PolkAudio CS245iPolkAudio F/X300i [surround] -
it has to be very small to attach, i always load them on sounddomain then click on IMG above the text box and give the link of the picture
Thanks Cody!
Here is a photo of the door before the Dynamat went in. I'll take updated photos over the weekend because I have to do the rear doors and install the crossovers and tweeters but this shows where the tweeter for the front door is located:Polk db6500 [front]
Polk db650 [rear]
Polk MOMO MM12 [2]
