LSi15 woofer upgrade
Hi Polks,
My current woofers are on there way out.
Is the MM840 or MM842 suggested latest woofer from Polk?
TIA
  • skrol
    skrol Posts: 3,480
    The Polk engineers came up with the DB840 SVC car subwoofer to replace the original woofers as an upgrade. Unfortunately they are no longer available. I don't believe that they made any further recommendation for the newer subs.
    I attached what I had collected as far as Polk 8" car subwoofer specs from a while back. I am not sure if it has the latest. Also, there was some conflicting info when different sources were viewed.
    Stan
    Main 2ch:
    HT:
    Other stuff:
