Amplifier for L800s
Hello,
Does anyone know if Mark Levinson 533H would work with the Polk L800s. They advertise it as fully-differential.
Thank you for your help.
Answers
    F1nut Posts: 51,912
    Fully-differential amps will not work with the L800.
  • Thank you for your quick response. Any recommendations for high end amplifiers that would work with the L800s?
  • From the speaker's designer, Scott Orth:
    "The L800 will not provide full SDA with a differential/balanced output amplifier. This is because the Dimensional Array is driven off of the positive leads only. So, half of the signal from a differential/balanced amplifier is on the negative leads. Hence the Dimensional Array only gets half of what it need to be fully functional. We have not had any amp issues using these types of amps."
  • I am an owners of Yamaha AS-1200 integrated amplifier. Now I am looking for new speakers. The polks L800 speakers have a special required for SDA mode. They are need to have an amplifier with single-ended circuit. I know the AS-1200 is floating of normal ground, It's not necessary mean is it don't have a 0 like Vref or not single-ended. Can you tell me if then Yamaha AS-1200 is compatible with Polks L1800? Thanks
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,291
    edited February 2024
    I found this in the owner's manual:
    This would reduce the amount of SDA signal produced by the speakers, so probably not a good match with the L800.
    This is from Scott Orth, the designer of the speakers:
    "The L800 will not provide full SDA with a differential/balanced output amplifier. This is because the Dimensional Array is driven off of the positive leads only. So, half of the signal from a differential/balanced amplifier is on the negative leads. Hence the Dimensional Array only gets half of what it need to be fully functional."
    pitdogg2 Posts: 27,187
    Step down to the L600's problem solved.
  • skipshot12
    skipshot12 Posts: 2,075
    Find yourself a complete WOPL converted Phase Linear 700.
    Personal preference… I like the Series II myself.
  • skipshot12
    Once the complete conversion’s done they test out in the 500w per channel range and the best part is, the crazy high damping factor they posses.
    I have two Clair bros converted amps. Was going to biamp my SDA SRS’s but only one is needed.
    Good luck with your search.
    F1nut Posts: 51,912
    Fun audio facts.
    To obtain that requires tons of negative feedback, which is not a good thing.
    In addition, the difference between a damping factor of 50 and 1000 is so, so tiny that it is a total and complete non-factor.
  • invalid
    invalid Posts: 1,509
    Fun audio facts.
    I would rather have an overbuilt big power supply than a high damping factor.
    audioluvr Posts: 5,977
    Since I never get positive feedback, I've learned to like negative feedback...
    nooshinjohn Posts: 25,963
    audioluvr wrote: »
    Would you like a participation trophy to make you feel better?
    audioluvr wrote: »
    Oh John, you tease!
  • skipshot12
    Y’all should really give one of those WOPL amps a go……
  • malo2464
    malo2464 Posts: 3
    Thanks for all your comments. I was already on the brakes with some bad reviews. Now I'm going to change direction.
  • malo2464
    malo2464 Posts: 3
    The Polk salesman and representative are not aware of the compatibility problem with the differential amplifier. This may be a case of wilful blindness.
  • skipshot12
    Fun audio facts.
    Ok….. is negative feedback on an ss amp bad?
    If so, why?
  • invalid
    All solid state amplifiers have negative feedback, otherwise they wouldn't work. It depends on how the feedback is applied and what type of amp it is.
    mhardy6647 Posts: 35,165
    edited March 2024
    There is no need for negative feedback per se -- ss or vacuum tube, direct, capacitor, or transformer coupled, class A, B or AB.
    Nelson Pass's famous (or infamous, depending on one's bent) and ultra-simple solid state "Amp Camp Amp" uses no negative feedback, for example...
    (EDIT: oops. :blush:)
    Negative feedback is used to broaden and flatten frequency response, decrease harmonic distortion, and reduce output impedance (i.e., "increase damping factor"). These are all Good Things.
    The trick is for the cure not to get worse than the disease. Think of Autotune. ;)
    Poorly implemented NFB can lead to many ills, some audible, some potentially disastrous (i.e., amplifier instability resulting in high frequency amplification and the rapid unscheduled disassembly, functionally speaking, of the amplifier when presented with a non-ideal (reactive) load -- such as the famous (or infamous, depending on one's bent) Polk Audio Cobra Cables -- or a QUAD ESL-57 electrostatic loudspeaker (which is nearly a short-circuit at 20 kHz).
  • invalid
    edited March 2024
    Can you Name one solid state amplifier that has zero feedback? The amp camp amp has local feedback. Even triode tube amps have feedback, the tube itself has feedback.
    F1nut Posts: 51,912
    skipshot12 wrote: »
    Fun audio facts.
    If so, why?
    I didn't say that. I said to obtain a crazy high damping factor requires tons of negative feedback, which tends to result in a lot of noise.
  • skipshot12
    Thank you for the explanation.
  • mpitogo
    mpitogo Posts: 520
    I spoke to Scott Orth about this topic way way back Nov 2019 as I bought the first pair. Try Rotel RB-1590. Or Parasound, they have some really good single-ended power amps. I went a different route, single-ended on top end and balanced on the low end. It’s a shame it doesn’t work with the PM-10. I’ve seen Polk demo the L800 with PM-KI Ruby.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
