KARMA Polk Audio SDA 1.2TL Crossovers.
Toolfan66
Okay, this is kind of a special 1.2TL Crossover KARMA.
These are not complete, I have robbed from them over the last couple years so you would have to do some work.
Now what makes them special is Ray (DargueKnight) designed the crossover boards, Ray was kind enough for me to get a set of these many years ago. As far as I know there was only a couple sets made.
The crossover plate can be included if you want it, I only have the one.
The dust is included.
You must be a standing member, I would prefer these go to someone that will actually put them to use.
Pick a number from 1-100
I don’t want anyone thinking they can’t throw their name in the pot, all I care about is someone will enjoy a project with what I would say is a one of a kind set of crossover boards, and you’re a standing member of the community.
I will let this run for the week
Post edited by Toolfan66 on
I'm interested Larry. Mine are upgraded but not with the larger boards or the newer inductors, etc. I'm in, thanks for offering this! In with 25.SDA SRS 2.3TL's
SDA 2B TL's -
Not in, but Awesome Karma!2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
In with lucky number 69... if I'm considered a standing member.My gear:
- TCL 75QM7K TV
- Onyko TX-NR656 AVR
- RT3000p Fronts
- CS1000p Center
- RT35 Side Surrounds
- RT35 Rear Surrounds
Guys, I will leave this open a couple more days, we are having our carpets done tomorrow morning so getting stuff out of the way is the priority at the moment..
I'm in with number 1. Thanks to you for a very nice Karma. I was just about ready to start buying the parts to build my crossovers for my 1.2 TL's and this would be a great jump start on the project.
Early morning pick!!
Ryan!!
Congratulations, very nice karma.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
GreatKarma Larry! Congratulations Ryan!
