Potencia total Polk magnifi Max AX sr
Buenas tardes, me gustaría saber la potencia total del equipo en watios, ya que no aparece por ningún medio ni sitio.
Me han comentado que tiene 200w pero me resulta imposible siendo el flashchip de la compañía y teniendo su predecesora la Max Sr 400w y está siendo superior, también se compara con la Samsung q990b que tiene 656w y me parece mentira que la Polk Max AX Sr tenga 400 o 200 o incluso menos...
Alguien me lo puede explicar?
Gracias por adelantado y un cordial saludo 🙏
Answers
    msg Posts: 10,593
    Loose translation via Google. Note, "loose".
    Y Bienvenidos!
    Good afternoon, I would like to know the total power of the equipment in watts, since it does not appear anywhere or anywhere.
    They have told me that it has 200w but it is impossible for me since it is the company's flashchip and its predecessor has the Max Sr 400w and it is superior, it is also compared to the Samsung q990b which has 656w and it seems incredible to me that the Polk Max AX Sr has 400 or 200 or even less...
    Can someone explain it to me?
    Thanks in advance and best regards
