Take 5
Willow
Willow Posts: 11,223
edited June 2004 in Speakers
when hooking up a take 5 system should they use sub out or should they wire the speakers through the sub?
thanks
  • dcarlson
    dcarlson Posts: 1,740
    edited June 2004
    That's the Energy take 5 your buddy has?
    Did he get a receiver and what does the manual say for the Take 5?
    Without knowing the system, I'd say if possible run it through the receiver. That will give you the option to play around the LFE settings on the receiver.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • Willow
    edited June 2004
    not sure I went online and their manual sucks big time.
    Yeah that's what he will be powering with what ever receiver he gets.
    I think he may lean towards the 5760 anything else maybe more than needs...
    I thought I would be able to look up the manual online and likeI said crap !! not sure if they considered sat/sub or small very small bookshelves.
