DBRX1 Wireless Adapter
I am looking for a wireless adapter that plugs into the back of a DBRX1 sound bar. Polk gave me a "mid-September" due date, but now they don't seem to want to follow up. Anybody have one they don't use or a reasonably priced DSW2 sub-woofer with the wireless adapter?
Thanks.
  • tagteam
    tagteam Posts: 1
    The audio is hard for me to understand - too much base. Is there any adjustment?
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,359
    Hello,
    Welcome to the Polk forum. There should be a remote control that came with the soundbar and it will have a bass level adjustment. You should be able to reduce the amount of bass with it. Also if you have the subwoofer near a corner or a wall try moving it out away from the wall or corner.
  • kenwbell
    Can't sync my dsb2 sub woofer with my dbrx1 soundbar. I do not have the wireless adapter, which i think is required to connect them. Is that true? If so, where can I get this adapter? It did not cone with the new sub woofer.
