CSI-A6 vs CSI-A4
I currently have a 3.1 setup, with RTI-A3 fronts on stands directly on either side of the screen, with a shelf directly above the screen for my center channel. My listening position is 10' away. I am replacing my JBL 120c center channel and am considering either a CSI-A4 or A6. Physically, either speaker will fit, but I'm debating whether the A6 might be overpowering based on my listening distance. Also, which unit would be a better match for my A3's?
Polk RTIA3 Fronts
Polk CSIA4 Center
Polk PSW Sub
Pioneer VSX-521-K AVR
And a friendly Labrador Retriever
Answers
  • la2vegas
    I agree with @Toolfan66, go with the A6. About 7 years ago I also had the RTI-A3's initially with the A4. I felt that I was missing out when watching TV.
    I shortly thereafter purchased an A6 and boy did that make a huge difference. It really bolstered my watching experience. The A4 has been in the closet ever since.
  • toolbelt
    I think I should mention I'm no audiophile, as 90+% of my viewing is news channels. But I do appreciate better sound regardless of my viewing habits. My center channel shelf is wide enough for the A6, but is only 10" deep, although there is nothing behind it. That said, the A6 will need to overhang the shelf by about 4" at its rear. I assume I can place non-slip pads anywhere along its flat bottom, and that it's not rear-heavy?
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
    F1nut Posts: 52,406
  • ChrisD06
    toolbelt wrote: »
    It's not Rear heavy. The weight of speakers is generally in the front where the drivers are because of how heavy the giant magnets are.
    Every Polk speaker I've owned has been front heavy. Don't worry one bit about the 4" rear overhang.
    And yeah I agree with everyone else on the A6. Especially as I assume you'll be buying used and the price difference between the two is minimal.
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
  • toolbelt
    ChrisD06 wrote: »
    toolbelt wrote: »
    The A6's are going for only $10 more, however, there are two considerations to take into account.
    The guy selling them has lots of other listings, focused mainly on used pro-grade gym equipment and associated reception area items. My guess is he's a liquidator. My assumption is that the A6's got lots of hard use at fairly high volumes in a gym studio setting. The A4's are a private-homeowner sale.
    Secondly, the A4's are Cherry finished and match my new (used) RTIA3s, and appear to be in mint condition.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • toolbelt
    ChrisD06 wrote: »
    toolbelt wrote: »
    And Chris, wasn't it you who warned me about going down this rabbit hole?? lol
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • ChrisD06
    toolbelt wrote: »
    ChrisD06 wrote: »
    toolbelt wrote: »
    I'd personally pick better sound over a finish but that's me (ignore the fact I spent years looking for a CS1000p with a specific finish). The A6 will provide deeper bass and that's very good for male voices. If the difference between the A4 and A6 is anything like the difference between the CS245i and CS400i, which I own both of, then yeah the A6 is going to be worth if.
    If you're concerned about it being driven hard, just check for signs of cosmetic use and also apply even pressure on the driver and move them in and out and feel for scratching. If it scratches then it's bad.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    toolbelt wrote: »
    ChrisD06 wrote: »
    toolbelt wrote: »
    Probably. I'm an enabler though.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • toolbelt
    ChrisD06 wrote: »
    toolbelt wrote: »
    ChrisD06 wrote: »
    toolbelt wrote: »
    You and that telekinesis lol
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • toolbelt
    A6, all day everyday and twice on Sundays
    You must really be a fan of Anderson Cooper? lol
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • rooftop59
    rooftop59 Posts: 8,120
    A6 if you can possibly fit it. Always go with the biggest center possible, all other things being equal…
    Game Room 5.1.4:
    Bedroom 2.1
  • BarbaraMohr
    I appreciate all for the advice, I will keep it in my mind.
  • toolbelt
    toolbelt wrote: »
    ChrisD06 wrote: »
    toolbelt wrote: »
    Ok, so I went and looked at the A6's and as suspected, they had plenty of wear on them, including a chunk missing out of a rear corner. So, I ended up getting the A4's. They are definitely enough speaker for my needs and I haven't even fine tuned my settings yet. They were in pristine condition and I love the cherry finish to match the A3's. Now I just have to figure out where to park the 4 RC Heli's I usually parked on my old flat-topped JBL center. :/
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • ChrisD06
    toolbelt wrote: »
    toolbelt wrote: »
    ChrisD06 wrote: »
    toolbelt wrote: »
    Good choice. Severe cosmetic wear is a guaranteed pass.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • toolbelt
    ChrisD06 wrote: »
    toolbelt wrote: »
    toolbelt wrote: »
    ChrisD06 wrote: »
    toolbelt wrote: »
    All things being equal, I likely would have gone for the A6, but the A4 is no slouch, especially in my 10 x 14 room. Must say I love the cherry finish. It's kinda modern and retro all in one package.
    Polk RTIA3 Fronts
    Polk CSIA4 Center
    Polk PSW Sub
  • boston1450
    boston1450 Posts: 7,759
    Congrats. Hope it sounds great for you
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
