perplexing 2.3TL issue
knie0012
knie0012 Posts: 48
edited September 2023 in Vintage Speakers
Good day,
Come seeking guidance and suggestion(s).
In short, I'm nearing the end of rebuilding a pair of 2.3tl's that sat in rough shape for over 10 years. Bought them off CL back when things were cheap, for 200 bucks, they were bad to say the least.
This is my current progress list:
I had a set of gimpod boards (I bought a decade ago!) I used to rebuild crossovers and created new mounting board.
All new sonicaps and mills (removed polyswitch and replaced with jumper)
All new jantzens inductors to include the large 16.0mH – 2.6DCR (all values I found reading here)
All new tweeters rdo198s
Replaced any dead and mismatched drivers with all mw6510s.
Blackhole5 behind all the drivers
hurricane nuts on all mounting points.
made a new interconnect using speakeasy ends.
I'm paying local woodshop to re-veneer the tops and bottoms.
bought a set of brass spikes based on suggestions here.
Oh, all new speaker cloth on side panels and front grates.
To say the least....I've got a lot of money in this rebuild (~1500 bucks, if not more?!)
The list above is from my research and months of reading on this forum. I did not do any original research or new approaches besides how I mounted my boards and large inductor.
As I type this, my cabinets are laying on their side with plenty of weight and I'm waiting for liquid nails to cure.
To "test" my crossovers and speakon interconnect cable, I decided to connect the #1 tweeter, 1 of 2 drivers in the sda circuit and 2 of 4 in the other with the wiring harnesses (odd approach I know).
My interconnect cable works as expected, such a nice cable interface!. Both "speakers play" but I've noticed by audio reasoning, the one crossover (channel) is not nearly as bright as the other. When I mean crossover, I mean the entire thing, all the drivers are more dull than the other side and the tweeter is not near as bright.
I've tried switching drivers, and tweeters to no change. I've tried changing crossovers on different channels (L vs R and vice versa). Tried changing my audio source, I.E. preamp, amp (running all adcom, solid state gear), applicable cables (different rca cables, etc).
Any suggestions that I can try or test? I've read the SDA Handbook and the table 4.4 in the handbook I don't believe provides values for the 2.3TL? Does anybody have any values that I can test the crossovers? I've donwloaded the old gimpod website to help with my crossover parts and build and that documentation doesn't seem to yield any specific DCR values for the 2.3TL.
As I mentioned, I have a lot of effort, sweat and money into these things and I hate sitting here and having a sub optimal result.
Thanks for reading! I hope some of you have a few magic bullets that can help!
Jason
    nooshinjohn Posts: 26,002
    I am not certain I understand the methodology of your testing. In my experience with a 2.3Tl and 1.2TL, all drivers need to be connected in order to do an accurate test, because the signal comes through the crossovers differently due to SDA. Also without having back pressure, the drivers are going to respond differently than they would if they were installed in a sealed cabinet as they were designed. My suggestion is not worry about the little stuff right now until I get the speakers back together again and then give them a go.
  • Very valid point and critique. To be honest, I have no methodology besides only what my ear is hearing. And, I think I am/was searching for a methodology to get solidified numbers prior to installing everything.
    I figured if the same parts/pieces were hooked up the same way on both channels/crossovers, it would be a gauge to ensure everything is working as is.
    Again, you're probably right and not sweat it until my build is reconstructed and address it then. To take it a step further, I've read countless posts about burn in, and 100-300 hrs before any judging should be had, so there's that, too.
    Thanks for reading.
    pitdogg2 Posts: 27,353
    The dimensional side plays at a lesser volume, the tweeters are a progressive point source and only one plays full frequency and volume. The other two play at a lesser volume and frequency.
    As far as I know, the only thing you can test at this point is whether the individual drivers work as intended, and that the ohm reading for each driver is within specifications for its use. Other than that, it’s just a matter of placing them back in their proper locations, making sure you have no air leaks in the cabinet and listen to them play. I think he will be fine if everything that you’ve done was done correctly.
  • Absolutely, good reminder, thank you.
    As of now, I have the top tweeter (full freq and volume) plugged in. Both crossovers are setup identical, i.e. same drivers/tweeter installed currently.
    The main drivers are playing louder than the SDA drivers, as expected. The tweeter is playing the full frequency. It's just they are all playing noticeably softer than the other crossover.
    Could something cause that quieter output off the crossover rebuild, bad capacitor or inductor. I have pretty accurate fluke/voltmeter. Was scouring for some 2.3tl numbers - or am I talking nonsense.
    For visual on what I'm doing, SDA drivers is the single on top.
    My board with harnesses plugged in.
    Crossover post rebuild.
    treitz3 Posts: 20,130
    Is the phase incorrect anywhere on the circuit?
    Toolfan66 Posts: 18,194
    Great looking crossover build..
    VR3 Posts: 29,554
    The issue is how you are arranging the drivers on the floor. (lots of cancelations)
    Try it like this
    https://1drv.ms/v/s!AqNfgHBkow_9t6QrsKa0b9XRvr_ZHQ
  • I guess if it was me I'd start by verifying that both crossovers are wired correctly and that all 5 inductors and 2 resistors have the same DCR values vs their comparable parts in the other crossover.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    VR3 Posts: 29,554
    If he is listening the way he showed that photo and came to the conclusion he has an issue... He really knows nothing about their operation.
    He needs to place them on the floor like my video and then he can start to run tests
  • Definitely not listening as the photo depicts! I've spread the channels out nearly like your photo but didn't have them facing forward, rather sitting flat. I would cycle the balancing from L to R, with and without the interconnect plugged in. This is how I'm interpreting the one crossover is playing at a lower db.
    That said, I should be able to put all components back together tomorrow or the next. I'll circle back here with results!
    Thanks for the patience, all!
  • gmcman
    gmcman Posts: 1,861
    Did you connect the stereo drivers the same way on both sides? The wiring is out of view, reason I ask is I believe the wiring is both series and parallel on different drivers to establish the final resistance, are you sure the loading is the same on both sides?
    Have you tried different songs to play or are you using the same track?
    As stated earlier, I don't know how you can accurately test without everything
    connected, even if what you have is even on both sides.
    What about amp loading? You could be dangerously low on resistance without all the drivers connected, but obviously without an ohm reading it's anyone's guess.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,309
    Hello,
    Good looking job on those crossovers. Do you happen to have a signal generator, a volt/ohm meter and an 8 ohm resistor?
    xschop Posts: 5,417
    If any of your drivers' spiders/suspension are sagging or setting where the voice coil is not centered in the base plate, Id highly suspect that too.
    6510's and 6511's are notorious for this issue.
  • After a long, long time, my rebuild is complete. Please don't judge me on my placement, it is temporary! ;)
    As for my perplexing sound issue that instantiated this post, that seems to have subsided as my crossovers are burning in. They are now coming into their own, sound and clarity wise. I bet I have 20-30 hrs on them since I completed my restore.
    That said, I was and still expecting more for sound stage. It seems to be a bit small for my effort and investment.
    I'm driving them with an Adcom 545 and pre amped with Schitt Saga. I did end up building a Dreadnought that I ordered directly from Avel Lindberg.
    I have moved on to my next project of rebuilding a pair of Altec 1570Bs that I have sitting around. I'm slowly gathering parts and pieces before I start the tear down - and still reading a lot!
    End goal is to refurbish them and do some pretty well documented mods to the amps that will make them sing! End goal is to mono block my 2.3tls with them?
    In any sense, my journey continues.
    Thanks as always for the help in the forums!
    Jason
    knie0012 wrote: »
    Don’t judge your placement? You were expecting more for sound stage? A bit small for your effort and investment?
    Don’t judge the speakers, or doubt your efforts, and investment till you get better placement, and better gear to power them with.
    I am judging, that set up is honestly horrible. Your crossover build is beautiful..
  • boston1450
    boston1450 Posts: 7,758
    Just wondering if the Adcom has been upgraded or anything else. Being it's age. I have had the 545 & the 555 & enjoyed them with the 3 preamps I used. Great amplifiers & preamps imo. They seem to blend well with SDA's. Not so good with RTA's (8 & 15tl) imo.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    VR3 Posts: 29,554
    edited January 2024
    After reviewing your photos I think I know your issue.
    You are using metal bolts on Gimpod boards. You need you isolate the metal from the inner hole as there is no isolation between the copper traces around the mounting bolt holes and the inner edge so your bolts could be causing issues.
    The recommended mounting hardware was nylon encased screws or plastic stand offs
    F1nut Posts: 52,012
    Good eyes Trey
    Very good eye..
  • Gardenstater
    Gardenstater Posts: 4,804
    You're saying a brass washer underneath could be shorting out traces, especially maybe the one with the arrow?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    VR3 Posts: 29,554
    the main issue is the inner part of the hole has copper traces that can contact the bolt. So if he is using that same brass washer on the underside and it is touching a solder joint or broke the coating on the trace and made contact it could cause an intermittent short.
    I speak from experience here. I had a customer run into issues with Gimpod boards installing them with metal screws/bolts for this very reason.
  • VR3 wrote: »
    I am using brass hardware - bolts, washers and nuts. I will replace with nylon and reassemble.
    I incorrectly thought the board coating was enough of an insulator, it seems
    You're suggesting and have experienced otherwise.
  • Just thinking as I re-read this, I want to keep my brass hardware for structure, but to eliminate the metal (brass) to board contact, I'll use a few silicone washers in place of the brass. That would isolate the metal off the board, retain structure, and stop any possible short.
    edited January 2024
    knie0012 wrote: »
    Just get these, they are stronger then you think, also don't use anything with silicone..
    VR3 Posts: 29,554
    You can use a nylon washer and heat shrink the top portion of the bolt that goes thru the board and be ok
    The nylon stand offs are amazingly strong. I'm perplexed as to why not use the same stand off that the old board used? When I did my 2.3tl's the new gimpod board went right back to where the old factory board was mounted with the same stand off matched right up to the new board.
  • Sorry, I misspoke when I said silicone - I meant nylon.
    As for the original standoffs, 3 were broke and the others were permanently bent (somewhat) from taking up the slack over the years. one of the speakers appeared to have fallen over at some point in its life as some of the internal bracing was lose, some of the magnets shifted on the drivers and the grill plugs were nearly all broke.
    VR3 Posts: 29,554
    Just so we are on the same page.
    The issue is that bolts are making contact IN the mounting hole and in return energizing anything attached to it and touching it.
    It is not just a problem on the back of the board
