PATH AUDIO RESISTORS ground wire to use or not?
Do I have to use this ground wire or can I just cut it off? I have never heard of grounding the case of a resistor. It complicates an already complicated project. If it is recommended to ground them then WHERE should I connect them exactly. I am leaning towards not grounding them. Any advise?
Answers
    VR3 Posts: 29,631
    Yes send to tweeter ground
    F1nut Posts: 52,165
    IIRC, Path says you don't have to use it.
    VR3 Posts: 29,631
    Better performance with it on a highly resolving setup with a low noise floor
