Audio Noob! Need Help with Recommendations!!
andrew55
I've had a Polk audio set in my family for many years and I want to try and get it working again. I have a PSW10 110V subwoofer with two M20 black towers and a CS2 center channel. I need a recommendation on budget receivers that I can use and a basic guide on how to wire them all together. Any help will be greatly appreciated. Thank you!
Welcome to the forum! This would be a good option:
https://www.accessories4less.com/make-a-store/item/marnr1510/marantz-nr1510-slim-5.2-ch-x-50-watts-a/v-receiver/1.html
You will also need speaker wire. Amazon and monoprice are the cheapest. A small upgrade would be bluejeans cable.
What will you hook up to these speakers? You might need additional cable depending on your answer…
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
