Polk Audio RTA 11T passive radiator rattle at full excursion
Answers
  • so I hook up my miller and kreisel subwoofer to see if it help on the lower notes. I turn my bass knob down a little on my receiver so the sub could take over the lows and it sound so much better. and I can go louder I also think **** down the woofer tight really helped to make sure it sealed well. So sorry if I wasted any of your guy's time. but these speakers sound really good and thank you for the help I just want to make sure they were sounding like there suppose to.
  • boston1450 wrote: »
    This is why I bought spare parts for my RTA15tl speakers years back. eBay & forum can be helpful. Hope you find issue & enjoy them. The 11's are well liked here. Keep in mind they are 30+ year old speakers & probably need crossover upgrades as well. So be easy on em
    can you please tell me more about the crossover upgrade?
  • boston1450
    boston1450 Posts: 7,758
    I had forum member (WMG) do my crossovers. There should be info archived here (search bar) as all my info is in laptop. I'm on the road
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    edited August 2023
    I have the RTA15tl also. Not 11's
    Randy-Maine
    by David WMG
    treitz3 Posts: 20,070
    VR3 wrote: »
    At the levels I listen to I can still talk to someone <snip>
    WAAAAAAAAAAAAA!!! Not when we come over!
  • boston1450
    Can't remember what tweeter they have in them. But you may be able to upgrade the tweeter to rd0194 (if available) & iirc if you do crossover TL you could do rd0198 (if available) . The rd194 is a drop in replacement upgrade. Nice sounding tweeter..... The rd198 is Polks best IMO for the TL drop in upgrade
    Randy-Maine
    by David WMG
  • boston1450
    Randy-Maine
    by David WMG
  • boston1450
    edited August 2023
    There is the difference in the crossover. The 11t doesn't say tweeter. I'm assuming sl2000 ? I'm sure someone will be able to walk you thru any questions you may have. I'm by far a good source :smile:
    Randy-Maine
    by David WMG
  • ok thanks for all the info
  • Godel
    Godel Posts: 21
    @nesman321 I'm having the same issue with one of my monitor 10b. I actually was logging in to ask about this problem when I saw your thread. I don't think your are playing it too loud if only one of them rattles. When using a tone generator at 25hz with medium volume I get the rattling. It comes from the PR not the inside of the box or the drivers. And if it was volume both of them would do it. I was reading the thread and I think I know what the problem is: I tried doing the air leak test that someone described here and noticed one of the PRs, has less resistance to my push and clanks against the spider. I think it might be that the material has lost some rigidity and it just 'gives' too much when pressure is applied. Could you test to see if the same happens with yours?
  • Gardenstater
    Gardenstater Posts: 4,799
    edited August 2023
    Exactly. Measure the clearance to the frame of each one and then also see how many dimes, pennies, nickels, or quarters it takes placed on each one's cone to bottom out the suspension. Shouldn't be difficult to do this. Just don't leave them in the displaced condition for more than a few seconds.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • @Godel I tried on both pairs and at 25hz I get rattling on both when played at medium volume
  • Godel
    Godel Posts: 21
    @nesman Finally found what the problem was with mine thanks to a suggestion at audiokarma, small section of the spider had come unglued from the metal basket. It wasn´t a problem until enough force was applied so that the parts colided with each other.
    Using some super glue I reattached evetrhin and now there´s norattling with 25hz at any volume level. Hope that helps. Another possible problem that someone else mention they had was that some cable had fallen into a position where it was close enough to the radiator so that they would bump against each other. It should be a simple mechanical problem. Hopefully its one of these.
    Ps: the thing that gave away the fact that the spider come loose was that when I pressed down on thee cone, the spider would deform and crease a little instead of just elongating uniformly. If you see creases when you press that should indicate that there are loose sections.
    pitdogg2 Posts: 27,217
    This would be the proper glue to use. Of course it will not dry super quick like super glue but it will last much longer and god forbid if you need to do it again you will not have the super glue nastiness to deal with.
    https://www.aleenes.com/original-tacky-glue
    F1nut Posts: 51,936
    Do NOT use super glue.
  • Godel
    Godel Posts: 21
    F1nut Posts: 51,936
    Aleenes has a slight bit of give to it whereas super glue or epoxy are rock hard, which puts the stress on the spider material instead of the glue.
  • skrol
    skrol Posts: 3,456
    Super glue also tends to leave a white residue from the out gassing of cyanoacrylate that reacts with moisture and oils and deposits on surfaces. You can actually use it to highlight finger prints. You probably don't want it inside your speakers.
    Stan
    Main 2ch:
    HT:
    Other stuff:
