LSi15 placement
Tank
Tank Posts: 8
edited June 2004 in Speakers
Howdy,
Just upgraded my system and now run all Polk speakers. My question is placement of my LSi15's. The owner's manual states that each has a "LEFT" or "RIGHT" on the serial tag, but they do not. The manual also says to set them up with the tweeters closest to the center, which is what I did. The bass grills face outboard. Is this correct?
Thanks,
Tank
Onkyo SR701
Sony DVD
Yamaha CD
LSi15 mains
CSi3 center
FXi3 surround
M&K MX-70 Sub
    VR3 Posts: 29,759
    edited June 2004
    yes
  • Tank
    Tank Posts: 8
    edited June 2004
    Man - that was quick! Thank you for the info. I really like those mains... my wife was understanding, yet a bit standoffish when I got them - guess she doesn't quite appreciate the hugeness of them.
  • Airplay355
    Airplay355 Posts: 4,298
    edited June 2004
    if you havent already, toe in the lsi15's so they point directly at your listening position ( if your listening position is like right infront of your tv)
    if you are sitting on side walls the dont worry bout it.
    lsi's tend to sound better when they are pointed directly at you
  • michael_w
    michael_w Posts: 2,813
    edited June 2004
    Just for future reference they should say something like LC or RC for left channel or right channel (well my lsi7s do anyways) instead of actually saying LEFT or RIGHT.
  • Tank
    Tank Posts: 8
    edited June 2004
    Thanks everyone. Yes, they are toed in to my sweet spot. They actually don't have anything indicating which side - I've been all over the back of them - the FXi3's do, but not the LSi's.
    Tank
  • Frank Z
    Frank Z Posts: 5,860
    edited June 2004
    The serial numbers will begin with either an "L" or an "R"
  • scottnbnj
    scottnbnj Posts: 709
    edited June 2004
    i think this is a personal thing and would, humbly, suggest experimentation.
    with my room and my gear and my listening style, i've found my lsi9's imaging is more detailed and open, and more often extends beyond the speaks, pointed straight forward when i listen near field and carefully concentrate on the music.
    however, i agree that for further away or when the sweetspot has to cover a wider area toe-in helps correct wall reflections, center and warm the image.
  • madmax
    madmax Posts: 12,434
    edited June 2004
    If they are new give them at least 50 to 75 hours or so to break in. They sound a LOT better after that amount of time. You will know when they break in!
    madmax
    Vinyl, the final frontier...
  • Airplay355
    edited June 2004
    ur right scott
  • gmorris
    gmorris Posts: 1,179
    edited June 2004
    Scott & I spent a week and a half getting my RTi70's setup just right. Scott was a big help. Here is a link to our discussion: http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=19750
    Try moving the 15's around, don't just plop them down where they look the best.
    Bob Mayo, on the keyboards. Bob Mayo.
  • Tank
    Tank Posts: 8
    edited June 2004
    I'll check out that thread.... thanks again to everyone.
    Tank
  • scottnbnj
    edited June 2004
    Originally posted by gmorris
    Scott & I spent a week and a half...
    well, schucks. thanks much, didn't seem like it took that long,.. of course i wasn't toting those rti70's all over the place.
    for lsi placement,
    lsi is just so sweet for precisely placing and putting space between closely situated instruments and vocals and exposing faint nuances that, to me, it just seems like a waste to push all of that information on top of itself and sit too far away to hear what all's goin' on.
    for me, if i needed to sit further away for stuff like entertaining others, waf, ear bloodying spl's and ht, i'd still set them up exclusively for near field and listen in a nice executive chair (that could be moved out of the way easily), then just live happily with whatever far field i got.
    of course, respectfully, i reserve the right to answer questions that no one has asked and be totally wrong about everything.
