Friend of mine needs help
Willow
Willow Posts: 11,218
edited June 2004 in Electronics
He will be driving his energy take 5. He is looking at a new receiver
which of these would be the best :
HTR 5760s
HTR 5790s
HK AVR230
mostly for movies and he likes it loud
thanks for the info
Post edited by Willow on
  • lonwa
    lonwa Posts: 83
    edited June 2004
    I have no experience with any of these units, but if all your friend really wants is for it to be loud, then choose the unit with the most watts per channel.
    Here is the disclaimer though:
    "just because a unit has more watts per channel than another, does not mean it will sound better, might even sound worst, or you could destroy your speakers by pushing them too hard with bad amplification."
    Hopefully this helps just a little in terms of getting your friends HT system to play loud. For me the quality of the sound is the most important part, then you can add more amplification to create a more dynamic volume range without distortion or corruption in the quality.
    Denon, Sony, and Marantz AVRs I do have experience with, and they all sounded good at more then loud enough volumes to make your ears bleed.
    Lonwa
    Sometimes good command decisions get compromised by bad emotional responses."
  • dcarlson
    dcarlson Posts: 1,740
    edited June 2004
    Willow, are you limited to Futureshop?
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • amulford
    amulford Posts: 5,020
    edited June 2004
    Turn him on to one of these:
    The Ultimate Receiver
    If he likes it LOUD and clean, he should shoot for this. I have one, in a 4500 sq ft house. It ROCKS!!!!
  • Willow
    edited June 2004
    No he is not limited to FS, I do know he wants to keep the price under 900$ and he seems to favor yammy or HK.
    This is a quote from him "I don't need to hear the crisp soud of violins or guitars, but my movies need to be loud and sound good"
  • dcarlson
    edited June 2004
    Lol, at least he knows what he wants.
    I have a Denon 2802, rated at 90watts/channel. It goes plenty loud and sounds great. The only problem is it cost me a little more than $900CDN. The Denon 1804 is in his price range and rated at 90watts/channel as well.
    I opted for the Denon over a Yamaha RXV-1400, to me the Denon seemed less edgy.
    You're in Ottawa aren't you? There must be a few smaller audio boutiques there. You guys should take a trip around town and hit a few different stores to have a listen at some options.
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2004
    HT sounds like the real preference, so either choice would suffice, and perform well for that application. I like HK, out of the two mentioned, but he should get the most AVR for his money regardless of brand name.
  • Willow
    edited June 2004
    He sure does....
    I have tried to inform him on others but he will not move it's either yammy or HK just not sure which of the choices above would be best for him.
    FOR me do you still have that link for canadian dealer of HSU or was it SVS. Please and thank you
  • Willow
    edited June 2004
    it seems $ for $ the yammy seems to offer more
  • amulford
    edited June 2004
    The Yammy will give him more features. The HK may edge it in SQ.
    You guys need to do some shopping, is all. Go check out both.
  • dcarlson
    edited June 2004
    For sure. And while you're at it, take advantage of the fact you have options in retailers. Most of them will probably price match with futureshop and at the same time you'll get to hear other receivers. ;)
