Insane speakers
F1nut
Probably ran with a Crown amp
I never thought to use human resonators for high frequency dispersion. Cutting edge technology!CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Madonna has her own line of phase plugs for these.
Single Ended 45 FTW.
Or, heck, maybe one of Bob Danielak's "Darling" amps. Single-ended 1626 for about 750 milliwatts.
https://www.tubeaudiolab.com/mike-mckee-s-1626-darling-set-amplifier
https://jelabs.blogspot.com/2019/07/darling-amp-je-labs-style.html
Watts are for wimps.
Or go push-pull KT88 and use 'em to remove paint.
Is there a sweet spot?
I haven't heard something like this but I have heard very large horns and I'm fairly confident I wouldn't like this- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Yep 😂 -
That's only because they aren't subs.I haven't heard something like this but I have heard very large horns and I'm fairly confident I wouldn't like thisI disabled signatures. -
A wheel of mozzarella.Gustard X26 Pro DAC
And here I thought Scott would be the one to come along with an incorrect, yet hilarious, response. Well done, Rob! 😂👍
Brian -
I here I thought it was the owners hemorrhoid donut for the sweet spot....
Does it come with Alexa?Don't take experimental gene therapies from known eugenicists.
