suggestions on changing cabinet from black to cherry stain
Dede
I'm picking up a pair of SAD 2 A's with a black cabinet (which I presume is an original-studio model ?). Any suggestions or prohibitions to change the surface to a wood stain? I'm thinking of applying a seal coat and then a color stain. Any thoughts as to if this would affect the sound fidelity?
Best Answer
^^^ That is your only option. No, it will not affect the sound.
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Answers
This will be interesting.Don't take experimental gene therapies from known eugenicists.
Paging F1nut ...
fortunately, no black paint is required...
https://forum.polkaudio.com/discussion/29186/where-to-buy-black-paint/p1 -
Vinyl will not accept stain. You'll need to remove the vinyl wrap, reveneer with cherry veneer then restain to your color choice
^This^Political Correctness'.........defined
President of Club Polk -
Synergistic research makes a black paint that supposedly makes things sound better if you decide to double down on the black- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
You should really cross-post this to the 'black paint' thread.
If I do that it may break all the links on his site and be lost forever...
On second thought...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Get after it kid!
