Ohms at speaker terminals & Ohms at interconnect terminal
Responses to my earlier question were extremely quick and helpful Thanks to all
Evaluating a potential purchase of used Polk SDA 1a speakers, using a multimeter, what reading of Ohms should I expect at the speaker terminals (my understanding is 4)? And what would be a viable Ohm reading at the interconnect terminals (also 4 ?)
Answers
  • Gardenstater
    Gardenstater Posts: 4,854
    SDA Handbook is your friend. 3.4 Ohms +/-20% and 10.5 Ohms +/- 10%
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • Dede
    Dede Posts: 16
    Thanks so much for your time and effort to provide the answer to my question. I would love to have a copy of the SDA handbook. I'll do a search and see if there is a copy on the forum-Thanks again-I appreciate your help
  • Gardenstater
    edited May 2023
    I can't seem to find the link to rev3 but here is rev2:
    https://us.v-cdn.net/5021930/uploads/editor/fe/zg3wih4m7prz.pdf
    I think it shouldn't be so hard to find.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,136
    Dede wrote: »
    Reading the resistance at those points does not tell you what the nominal impedance of the speaker is.
  • Dede
    Dede Posts: 16
    I am not particularly sophisticated in these areas; what would that make a difference? How does one measure the nominal impedance of the speaker and how is that different than the terminals? For purchase purposes
  • skipshot12
    skipshot12 Posts: 2,103
    edited May 2023
    Impedance changes with frequency?
    treitz3 Posts: 20,203
    You can have a speaker rated at 4 ohms nominal (not under load). With that said, some 4 ohm speakers can dip down well below that during heavy demands. For purchasing purposes, you need to look at an amps performance under load (is it a high current amp?), as well as the speakers under a load. It's best just to ask and be patient with/for the answers.
    The thing is, no manufacturer likes to devolve this kind of information. It is mostly found out through speaking with owners, or a "reputation" of a speaker/amp. Case in point would be the Original Carver Amazings. It's rated at 4 ohms but by now, most everyone knows that it can drop down to an almost dead short under load and that dropping down to 1 ohm is pretty common with them.
    Spec's only offer a glimpse of what a system's or component's performance will be like.
    pitdogg2 Posts: 27,530
    The key word here is "nominal". Which means in use they could by 5.5 ohms or 2.8 ohms....
    F1nut Posts: 52,136
    skipshot12 wrote: »
    Bingo! The nominal impedance is an average or the majority of the range.
  • skipshot12
    An example, Infinity Kappa 9’s were rated either a 4 ohm or an 8 ohm speaker from Infinity… don’t remember.
    But, there were two points in its frequency curve that they dipped to 0.8 ohms, a beast of an impedance to drive if one doesn’t have a proper amp.
