Sda Srs room treatment recommendation for smaller room
Any advise on wall treatments to eliminate side wall deflections for better sda in a smaller than optimum room?????
Everyone have 20 fricken feet?
Answers
    txcoastal1 Posts: 13,519
    The SDA SRS produce bass...so first thought are bass traps in the corners, starting with the corners behind the speakers.
    First reflections on the side can depends on seating position in correlation to the speakers. You can use a mirror on each side wall. Sit in sweet spot and have someone move the mirror on the side wall until you see the reflection of the speaker.
    This may need to be adjusted pending on what you hear.
    Unless you really get into real calculations using software and mics, most is trial, error, budget and listening habits
