Magnet Fell Off MW6502
Hi all,
I purchased a pair of Polk Monitor 4s off eBay. They are dated 1989. The packaging was superb, and I saw no damage to the box. When I took the one cabinet out of the packaging, I heard a thumping from within as I set it on the table. I immediately knew what it was but couldn't believe it. The magnet didn't shift; it fell off the driver and was rolling around inside the cabinet. The coil is damaged, so this particular driver will go out in the trash this week.
It takes a lot of force to pry a shifted magnet off the driver, so I'm curious as to what happened. Did this phenomenon happen to any of you? Did UPS drop it off a several story building?
Thanks,
Brian
    pitdogg2 Posts: 27,353
    edited May 2023
    If the magnet was already compromised it could pop off if dropped and hit just right.
    Welcome back stranger 😜
    xschop Posts: 5,417
    So the shipping box wasn't bent/damaged in any way?
    Got pics?
  • decato
    decato Posts: 189
    I've been lurking in the background!
  • decato
    decato Posts: 189
    xschop wrote: »
    Got pics?
    No damage, at least no punctures or dents.
    Nah, I threw the driver in the trash and cut up the box. I had a few spare drivers, so I'm ok but still stumped.
  • decato
    decato Posts: 189
    edited May 2023
    I pulled it out of the trash. Fortunately, there wasn't much in the trash bin!
    I completely destroyed the coil after I saw it was already damaged, so please ignore that part. However, you can see where the glue failed.
  • bcwsrt
    bcwsrt Posts: 2,521
    I half-heartedly joked before I got around to J-B Weld-ing my 15s that whenever I listened to them at elevated levels I was nervous I would hear the "THUNK!!" of one of the magnets hitting the bottom of the cabinet. I didn't realize they could actually do that! 😮
    Brian
    xschop Posts: 5,417
    It's repairable.
    F1nut Posts: 52,012
    Wuhan voice coil to the rescue.
  • decato
    decato Posts: 189
    Heh, it's going right back in the trash bin. Still, based on the comments posted thus far, it doesn't seem like magnets falling off is a common problem.
    xschop Posts: 5,417
    Strange indeed. PM incoming.
    xschop Posts: 5,417
    Wubay coils are about here.
    xschop Posts: 5,417
    edited May 2023
    These should fit perfect without any former trimming at 33mm length...
    3.5 ohms DCR too
    The highest reading one oscillates between 3.6 and 3.7 Ohm on the multitester, but all register 0.20-0.22mH inductance...
    Post edited by xschop on
  • decato
    decato Posts: 189
    I look forward to seeing your repair of the damaged driver.
    How does the inductance of the replacement coil compare to that of the original MW6502 coil?
    xschop Posts: 5,417
    Im not 100% sure that the factory coil should be measured while installed. But got tester leads closest to coil. The other unknown is these 6502's are phase-plugged and focus-ringed, which may be reducing inductance?
    xschop Posts: 5,417
    edited May 2023
    This is another caveat I like about 6502's besides their outstanding midrange. The doping compound is always applied uniformly and the dust caps are concentric.
    This one got fragged severely but definitely worth saving...
    I made another shorter Coil spud jig just for this little delicate cutting operation...
    Cut the coil former slit with a razor sharp scalpel and then scroll it out...
    xschop Posts: 5,417
    edited May 2023
    IMO Polk got these right also because the Base Plate IDs are always between 1.085 and 1.090". This one has the galvanic corrosion (albeit lighter than what I've seen on 6500's, 6510's 6511's...
    Light drum sanding to remove corrosion and these will never coil rub again...
    Not sure what the markings mean on Base Plate...
    Wubay Coil OD's are all 1.070-1.072"
    Dual-layer too looking under mag glass...
    Before gluing in coil, I apply a thin layer Aleene's Tacky Glue between spider edge and cone edge ID's...
    xschop Posts: 5,417
    edited May 2023
    Glue setting with 0.010" thick shims...
    You want to make sure the length of the coil is exactly centered with Base Plate thickness while the spider is in a straight/flat plane front-to-back
    xschop Posts: 5,417
    edited May 2023
    Magnets usually come centered with pole-pieces from factory on 6502's also. I won't even bother removing and re-setting when I go to add a focus-ring and phase-plug.
    Another bonus besides being the correct Polk 26mm ID's, they appear to be easily modified/un-wound a few tenths of an ohm to get them to the Polk published DCRs of the 6511's...
  • decato
    decato Posts: 189
    It's coming along nicely!
  • Gardenstater
    Gardenstater Posts: 4,804
    edited May 2023
    Definitely a larger VC I.D. than on the 6500. I have 1.008" PVC plug gage that is a slip fit to mine, so they are around 25.6mm I.D.
    Nice pictures and tutorial! Looks like you got an Xmax that is even greater than 1/8" there.
    Oh.....and the BD0602-A being the Polk part# for the driver, the D0654-1 must just be the part# for the baseplate? Wonder what the company was that was fabricating them at the point where they were being made in Mexico. I guess Mexico was not using the EIA Source Codes.
    This morning's research reveals one way to measure BxL. I wouldn't have thought it was safe to put that much DC current through a VC but I guess it is ok for short period of time:
    Post edited by Gardenstater on
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,417
    edited May 2023
    That's an interesting method I'll have to try sometime.
    I just remembered that my little tester was causing a pulsing signal to be emitted from the cone as it was performing it's test.
    And yes these particular coil lengths are 0.55" long compared to most factory ones I've measured at @ 0.51" coil length. So only 20 thousandths extra length either side of the base plate stroke.
    Just measured this one's ID at 1.018"
    I don't pull any punches and have to say these are stronger and better built than what left the factory. 100% concentric with no deformities in the former or wavy flanges.
    xschop Posts: 5,417
    edited May 2023
    Glue completely dried, removed shims and soldered leads back in location, trimmed excess, then painted them and the exposed bare cone area. They need a thorough cleaning after paint dries.
    .....As of late, been trialing a rubber rejuvenating admixture since I believe the doping compound to be latex...
  • Gardenstater
    edited May 2023
    Does your rejuvenating process leave the surface sticky like they were when new? Another question is whether the stickiness is a key feature of the damping effectiveness or not.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,417
    edited May 2023
    I originally started applying the solution to the butyl surrounds that are dry and micro-cracking near cone edge. I noticed it also seems to be making the doping a little more tacky, yes.
  • decato
    decato Posts: 189
    What product did you use on the rubber surround and cone? I have accumulated some drivers that are in rough shape.
    xschop Posts: 5,417
    1 part wintergreen oil to 1 part 70% isopropyl alc.
  • decato
    decato Posts: 189
    Interesting. Thanks!
