Changed up the TV room a little bit
Took around 6 hours and a lot of coffee, but I think it turned out alright. Biggest upgrade? No more crappy 5W Samsung TV speakers.
Now we're driving some Polk Audio RT800s which I painted black with a 90W RMS Sony stereo. What a difference!
Here's my question for you folks. What do you think suits the room more: Mesh on, or mesh off?
My gear:
  • TCL 75QM7K TV
  • Onyko TX-NR656 AVR
  • RT3000p Fronts
  • CS1000p Center
  • RT35 Side Surrounds
  • RT35 Rear Surrounds
  • Emlyn
    Emlyn Posts: 4,888
    The RT800s look good. I prefered my RT series with grilles on even though the later version with the blue drivers looked cool.
  • ChrisD06
    ChrisD06 Posts: 929
    @Emlyn
    Agreed. The blue drivers were really cool, infact, with my RT600i, I actually keep the bottom grille on and the top grille off, looks pretty nice in my opinion.
    The only RT speaker I objectively think needs the grilles of in all cases is the RT3000p. If you're not showing off their subwoofers then what are you doing???
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • PSOVLSK
    PSOVLSK Posts: 5,433
    Looking good. I think I prefer the grills on, but either way looks good.
  • ChrisD06
    ChrisD06 Posts: 929
    @PSOVLSK
    Yeah I'm thinking grilles on it is, it also keeps dust out to be fair.
    Grilles off for the HT setup of course! Considering throwing a PSW 350 upstairs but I have no idea where it'd fit LOL
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    Clipdat Posts: 13,101
    Bring the speakers out and away from the rear wall a bit, instead of having them butted up right against it.
    F1nut Posts: 52,298
    edited May 2023
    Grills on, move out from the wall and toe in.
  • Willow
    Willow Posts: 11,339
    You lie... Everyone knows you can't find black paint.
    Looking good
    VR3 Posts: 29,697
    I would say that's more of an onyx then black, compared to the grill
    The search continues for this elusive paint no doubt
    Looks good!
  • ChrisD06
    ChrisD06 Posts: 929
    @Willow @VR3 Thank you both!
    Highly recommend this by the way. If you have an old RT (non i) series speaker and the fabric is damaged (if it's fine, leave it be), then peel it all off and paint them black. It looks super sleek and modern and matches the black of the RTxxi series or the later model RT3000p which I coincidentally own. Infact, that's how I found the paint I wanted lol.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    treitz3 Posts: 20,276
    Those were my first model of Polk speakers I ever owned. Long time ago. They were a fun speaker and kinda wished I had kept them for a secondary system.
    I'll agree with bringing them out from the wall and toe in. Also, see if you can find something heavy to place on top of them......and add spikes with pucks to protect the floor. All of this will make a big change to the end result. FWIW.
