Epoxying Magnets - What to Check Beforehand
_LongWalker_
I'm pretty darn novice when it comes to audio and audio DIY. I just bought a pair of Monitor 10b's in great condition, and from some reading here, it seems I'd be wise to glue the magnets in place. A 2-part fast epoxy is highly regarded.
Before I attempt this, is there anything I should closely check before applying any type of glue? Make sure the cones are moving freely, and not just with one finger? Anything sound related? And here's probably the silliest question: it's only the mid drivers that I need to be concerned about regarding magnet shift, right?
I'm asking because it seems if I were to glue prematurely, before catching an actual flaw, I'd be in a worse condition. Speakers sound fantastic btw.
Thanks!
Thanks!
Use JB Weld, do not use 5 minute epoxy. Apply to the top and bottom around the magnet.
Yes, only the mid-drivers.
With fingers spread out evenly gently press the cone in. You should not hear a scraping sound.Political Correctness'.........defined
President of Club Polk -
I will say that if your speakers have MW6500s, which have a tighter clearance between the VC O.D. and the top plate, I would not use JB Weld because that will be a lot harder to remove should you encounter a rub as they age. I was glad that I didn't on my original 6500s. The Gorilla Max Strength Clear was hard to remove but not impossible. Now I can repair the drivers when I get to it. Future mod platform is what they are now.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
A rub as they age...LOL
That's ridiculous, they are aged already.Political Correctness'.........defined
OK sir, would you prefer as they are played further? My speakers aged quite a bit in their first 5 years of life and were played quite excessively loud
The more they are played and the louder they are played, the more worn the suspension parts get. What is ridiculous is having to defend the obvious. George / NJ
iFi nano iDSD DAC
iPurifier3
I've been playing various Polk speakers excessively loud since 1986. Never a problem.Political Correctness'.........defined
Good for you man. Which ones? The more drivers in the cabinet, the less the individual displacements for a given sPL. Then there is also the quality of amplification and the random element of assembly errors such as a cocked voice coil (etc.) that could easily make it through incoming inspection without being detected.George / NJ
iFi nano iDSD DAC
iPurifier3
Okay for the sake of the argument.
Lets say the suspension wears out, are there new suspensions we can buy and replace the old "worn" out suspensions? If so kindly point me in that direction, I'll buy 12 or 20 of them. -
Right. But in any case, with mine recently being firmly J-B Weld-ed in their 30 year-old places, if something bad happens next, I’ll feel like I definitely got my money’s worth and move on to some new speakers.
Brian -
Gardenstater wrote: »I've been playing various Polk speakers excessively loud since 1986. Never a problem.
CRS, CRS+, 2B, RTA15TL, Monitor 7, Monitor 11, 2.3TL and multiple RTiA models.
Stop over thinking each and every damn thing, you'll live longer.Political Correctness'.........defined
I never met a good engineer that didn't question everything lol.
Where there's a will, there's a solution. Alot of people have just tossed the drivers before, when the coils start rubbing.
These spiders are all 4.0" OD x 1.0 ID x 0.5" tall with 6 pleats
The 6502's are a thicker thread/weave than the others and I have never seen or heard of one's coil rubbing.
Ticking time bombs...
6500's
6503's
6509's (probably safe as large BP gap)
6510's GL finding any not worn
6511's GL finding any not REALLY worn
Post edited by xschop onDon't take experimental gene therapies from known eugenicists. -
Maybe you can get the surrounds from Simply Speakers. Are they the same compliance? I don't know. But my point was that if you don't glue with epoxy but choose something that is not so hard to remove but still gives you a tenacious impact resistant bond, you will be more protected in the future and will be able to realign the magnet motor without so much grief.George / NJ
iFi nano iDSD DAC
iPurifier3
Every one you mention except the Monitor 7 has 2 or more drivers, which makes them more resistant from over extension at high sPL's. That causes damage over time to the spiders which are basically cotton fabric impregnated with phenolic resin.George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »Gardenstater wrote: »I've been playing various Polk speakers excessively loud since 1986. Never a problem.
LMAO...Political Correctness'.........defined
In the interest of accuracy it probably only holds true for multiple stereo drivers, that the incidences of over excursions will be less for high sPL.George / NJ
iFi nano iDSD DAC
iPurifier3
OP has two-driver 10s. Probably sorry he started this thread. Lol
Brian -
Hey OP, welcome to this site!!
Thank you for the "solution".Don't take experimental gene therapies from known eugenicists. -
Was not jesting with that comment. Last year when I plugged the original 6516's for the 8TL's, I noticed one of the spiders was more giving/loose than the others. I taped everything off and sprayed a layer of ironing starch on the spider and let dry. It tightened it up very close to the others. I took them out week before last when I installed focus-ringed and phase- plugged 6516's....and it is still holding up, no deterioration. I figured the resin George mentioned could be made into a solution and sprayed as well, to rejuvenate all these old drivers' spiders...Don't take experimental gene therapies from known eugenicists.
The only deterioration I have experienced with the MW65xx (MM65xx for mobile) series spiders is the glue detaching from the basket. That was on two MM6500 and one MW65xx. I just glued them back with a little epoxy and no problem after.
I have seen shifted magnets cause rubbing and locking. If the VC starts rubbing from loud play, it may be that the VC has deformed due to excessive heating of the coil.Stan
Main 2ch:
HT:
Other stuff:
Yuuup.If the VC starts rubbing from loud play, it may be that the VC has deformed due to excessive heating of the coil. -
Both of my originally equipped MW6500s left the factory with cocked voice coils. They are on the alignment fixtures I built and are being coaxed back into alignment by combination of time and blow dryer heat cycles. Neither of them scrape when manually pushed anymore but the VC being cocked is only improved slightly (that's how bad they were built). One of them developed a crack in the spider during it's service life but it was not at the attachment point to the cone and VC. It was near it. Only detectable visibly when I over extended the cone forward. I'm sure the VC being cocked didn't help but neither did my playing them super loud when I was in college with a 55WPC receiver. The VCs never overheated though and are perfectly round as far as I can tell. You can see where they were rubbing on the front plates however by scuff marks in whatever the wire is coated with. They still ohm out correctly at 6.5 ohms.
Scuffing from cocked VC's:
This picture gives some idea of how gauz-y the spiders really are (black basket backup driver):
Post edited by Gardenstater onGeorge / NJ
iFi nano iDSD DAC
iPurifier3
Clearance the Basplate ID and install some focus rings already.🙂Don't take experimental gene therapies from known eugenicists.
I'm actually leaning towards making the front plates alignable/adjustable and leaving the gap what it is, so that the Bxl remains in spec and sensitivity doesn't get reduced.George / NJ
iFi nano iDSD DAC
iPurifier3
Do your 6500's have a slight air-gap between base plate and frame where the rivets attach?
I've been finding a few that have this QC issue also, which translates more vibration into the pole-pieces. Remedied one with HDPU and will compare the other with 2-part epoxy in the gap.Don't take experimental gene therapies from known eugenicists. -
Can't see any light, but the depth to which you can insert a 0.005" feeler gage varies between the two drivers and varies around the circumference of the front plate. This could be part of the problem with the cocked voice coils.
Mine seem to have come into alignment after almost 14 mos. on the fixtures I made lol.
But in order to get a 1/8" extension of voice coil you have to make the spiders decidedly concave dish shaped because they were manufactured at only 1/16". That's the next issue to be fixed.George / NJ
iFi nano iDSD DAC
iPurifier3
Another data point that might be useful (and supports F1's comments).
I've played the **** out of my 10B's for over 25 years...and I just epoxy'd them (JB Weld) a couple of years ago before a big move. Once you confirm they are 'good', just do it and don't look back; this is one of those things where an ounce of prevention is worth way more than a pound of cure. The only negative is it's messy/smelly...so make sure you have plenty of ventilation (and wipes).Yamaha RX-A2050 AVR (5.0.2); LG OLED77C2 4K TV(4) Polk Monitor 10B's w/SoniCaps, Mills, and RDO-194 tweets (R/L F/R)(2) Polk RC80i (Top Middle)Polk CS300 center channelAnalog: B&O TX2 Turntable, Nakamichi Cassette Deck 1Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-RayBedroom: Arylic Up2Stream AMPv3 driving Polk Monitor 4's w/peerless tweets -
If a driver works I just go ahead and epoxy it.
my 3.1TLs
I will fix your shifted magnets for free.
