Capacitor value
nemohm
nemohm Posts: 19
Hello All,
I have a capacitor to identify. Could be 72pF, need confirmation, please.
It is the second capacitor in series with 3.3uF in the first order high pass speakers filter. I believe it is for phase correction. There is 10wR4 between capacitors
I'm looking to replace it with a better quality one, non-ceramic?
Thank you again,
  • Gardenstater
    Gardenstater Posts: 4,866
    It might not even be a capacitor. Could be a MOV or a polyswitch.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • nemohm
    nemohm Posts: 19
    edited April 2023
    Then better keep it untouched? Do they age?
  • Gardenstater
    nemohm wrote: »
    Those components I mentioned, which yours may or not be, definitely are known to deteriorate and even fail.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,244
    edited April 2023
    nemohm wrote: »
    Hello All,
    Thank you again,
    It is a 60V 0.75A Radial Lead Polyswitch, which is a thermal reset device. It acts as a fuse of sorts. Generally, the device will have a resistance of 0.5 ohms. If you remove it (highly recommended) you should replace it with a 0.5 ohm resistor of at least 5 watts, 10 is better.
    When asking for help like this state what speakers you have, so what speakers do you have?
  • nemohm
    nemohm Posts: 19
    edited April 2023
    Hello, Thank you very much for your suggestions!
    After years of stale audio interests I decided to get back on the field. I have Denon AVR used for stereo only. Kef HTS3001SE that I'm not happy with. The room response is pretty much on the inferior side.
    This is how my saga started.I was able to get RTi150 for very optimistic price. The first (and last) hookup (2x80W) was devastating.
    The drivers were flapping, extremely muffled sound. Same outcome with mid/tweeter hookup only. Tweeters are blown. Not sure if the speakers came with blown tweeters (not tested at the point of sale) or were blown as a result of my AVR clipping. Or faulty crossover (s). Took the speakers apart and measured Re of drivers.
    Woofers are 1.3ohm each, serially connected; mids are measured 3.4ohm. No wonder the speakers are exceptionally power hungry ones. Sourcing tweeters or replace with 3rd party ones, can't figure it out. Fear to have a hookup again with new tweeters.
    Despite the fact the speakers are "8ohm compatible" according the manual.
    The part under question is from friend's DQ QX6A speakers.
    0.50hm 10w resistor is hard to source though, too many types, too many series of the same resistor.
    My best hit is Solen MOX 1ohm 10w, 2 in parallel. Hope this works.
    Much appreciated!
    (BTW, I found exactly the same component on AliExpress...)
  • Gardenstater
    Have you measured the resistance of that suspected polyswitch? If it is a 0.5 Ohm one when it isn't shifted or blown, then here is a good replacement:
    https://www.soniccraft.com/product_info.php/050-ohm-vishay-mills-mra-12-p-5332?osCsid=sojbji2ue07n5ni2putf4skd70
    What exact component did you find on AliExpress? The polyswitch? Show us a link :)
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    Maximum Post Trip Resistance = 600mOhm
    Minimum Untripped Resistance = 250mOhm
    Maximum Untripped Resistance = 400mOhm
    https://www.arrow.com/en/products/rxef075/littelfuse
    No specs here:
    https://www.aliexpress.us/item/2251832646848137.html
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • nemohm
    nemohm Posts: 19
    It is typical for AliExpress to provide no details.
    There is pic from the measurement:wg8hu97cihl3.jpg
    The resistance fluctuates 00.2-00.4, initially could go to 6-7 briefly.
  • nemohm
    nemohm Posts: 19
    edited April 2023
    The Polyswitch is available even in Canada
    https://www.digikey.ca/en/products/detail/littelfuse-inc/RXEF075/5015922
    Time for reaction is 6.3 sec --Is it not enough to fry the tweeter?
    A resistor of 0.5 ohm (or else) as replacement - would it be better or in disadvantage?
    Thx
    F1nut Posts: 52,244
  • Gardenstater
    edited April 2023
    nemohm wrote: »
    Thx
    I was shocked at that reaction time as well. It also said max. of 3.75 A (so even longer to trip at 1.5 A ?) The fast blow fuses for the Peerless tweeters in my 7Bs are 1 A.
    People who omit the Polyswitches have said they contribute to audible distortion, especially after they have tripped multiple times. I don't know which would sound better, an untripped polyswitch or a fuseblock with a fuse. My fuseblocks have ferromagnetic rivets that Polk used as the conductor. There are those such as Danny Ritchie who claim that any ferromagnetic materials in the conductor path can cause audible effects that are negative.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • nemohm
    nemohm Posts: 19
    -Omitting the switch in a whole is one option I'm considering.
    -Replacing the switch with resistor as suggested by F1nut. But will the resistor provide any protection?
    -Searching for switch with faster reaction..
    - Fuses - kind of cumbersome and seldomly used solution.
    Which way to go?
    Thx
    F1nut Posts: 52,244
    If you think you need a fuse or polyswitch you shouldn't be playing this game.
  • nemohm
    nemohm Posts: 19
    With all due respect, I'm confused - what is the game here?
    Could you please elaborate?
    I'm not sure of anything related to electricity. (my background is in mechanical engineering).
    Not sure if such switches are common and effective and if they do good or harm, nor what the resistor replacement does.
    I was surprised to find that component within a crossover, never seen one before in my very limited experience.
    Just looking for a piece of advice from knowledgeable people...
    F1nut Posts: 52,244
    Just replace the polyswitch with a resistor and be done with it.
    pitdogg2 Posts: 27,686
  • skipshot12
    skipshot12 Posts: 2,114
    nemohm wrote: »
    Not at all uncommon to find poly switches in a speaker’s crossover.
    What gives you the surprise to find them in a crossover?
  • skipshot12
    As said above, measure the resistance of the switch and replace the switch with the same value resistor.
    If you’d like to play with the sound of your speaker you can also try different value resistors or jumper to remove it completely.
    One word of caution when jumpering/eliminating the switch… make sure you have plenty of clean power so your amp never goes into clipping. Bad stuff happens with under powered gear when the switch has been eliminated.
    If driving with a receiver it would be wise to not eliminate the poly switch.
  • skrol
    skrol Posts: 3,483
    The problem with measuring the resistance of the polyswitch and replacing with a resistor of that value is that if they have ever tripped, they don't go back to the same resistance (usually higher). Best to find a spec sheet for the polyswitch and use the value for untripped. Or just replace it with a 0.5 ohm resistor as is commonly done for that polyswitch.
    Stan
    Main 2ch:
    HT:
    Other stuff:
