MAX whats up with the sub??!!
CHRIS
CHRIS Posts: 454
Chuck-Just wonderng what you have done.
Chris :)
  • madmax
    madmax Posts: 12,434
    edited January 2002
    Chris,
    I received the 250 watt amp (with remote control) and a 12" Titanic (not the MKII) last week and just yesterday I received the Adire 15" Passive radiator. Over the next few months I'm going to gather some tools and make my own box to put it in. I spent the last few weeks reading the Parts express tech forum and the many links I found there trying to figure out how to design what I want. (not nearly as easy as I thought). At this point I have settled for a huge box with the PR because it is flat down to 20hz with an f3 of 15.5 hz.
    I could go half the box size with two titanics face to face but that would use twice the amp power, cost twice as much and still be 3db lower in sound pressure.
    I think you would like the PE tech site.
    madmax
    Vinyl, the final frontier...
  • CHRIS
    CHRIS Posts: 454
    edited January 2002
    Chuck thanks for the update, sounds like it will be a killer sub. I have checked specific things on PE tech I guess I'll have to really check it out.
    Chris :)
